Thread: Pool Water Change, Question about best numbers?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I just did about a 65% water change(Trichlor) to lower CYA, that was fun...
    My pool is Pebbletec Inground
    After some adjusting I have:
    CL-4
    pH- 7.4
    TA - 110
    CH - 250
    CYA - 30-40
    Borates - just started adjusting back up from 15
    I don't have to add water very often, rain usually takes care of that for me in S. FL.
    If I adjust the CH, it will pretty much stay where I put it.
    What would be the best number? I shot for 250 and that's where I have it, but wondering if there would be a more "ideal" number.
    I'll re-check the TA after the Borates are done, what would be perfect for TA?
    How would these numbers best be set if I were getting ready for SWG?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Water Change, Question about best numbers?
    Quote Originally Posted by les_garten
    pool-school/water_balance_saltwater_generator
    38,370
    Don't add more borates until your TA is in the correct range. The recommended level for TA is lower for SWG than puck usage.
