Thread: What is "normal"?
    tcat's Avatar
    May 2012
    Austin, TX
    730
    What is "normal"?
    If you are not having algae problems, what is "normal" for pool maintenance? (mostly interested in chemical amounts)
    My "normal":
    Add 30 oz. Clorox each morning
    Add 8 oz. MA about every 3 or 4 days (not sure why pH seems to creep up)
    Empty skimmer basket once per week (unless it's been real windy)
    Empty pump basket about once per month (never has much in it)
    Empty Legend Platinum about every other week
    Backwash about every other month
    Shocked once this summer when I forgot to add Clorox one day (FC got too low)
    (did some brushing for a couple days then)
    Jump in daily.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Oct 2011
    New Caney, Texas
    414
    Re: What is "normal"?
    Empty the skimmer every few days.
    Brush once a week.
    Vacuum once/twice a week.
    Clean the filter every month or two. (when flow slows)
    Check FC and PH almost daily, other chems every few months. (PH very stable almost no MA used.
    Hear daddy can we go swimming daily, go swimming almost daily.
    What is normal? NEVER worry about the pool. As daughter says; looks all sparkly.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Bjarni's Avatar
    May 2012
    Albuquerque, NM
    51
    Normal is relative, meaning that you are going to get many different answers based on many a different variables.
    I can tell you that for me, I add a little over a quart per day of bleach (34 to 36 oz) This varies with bather load, sun, wind, etc. It also has a lot to do with your CYA level.
    I empty my skimmer basket every couple of days, but I check it daily.
    Empty pump basket every couple of months.
    I brush only monthly. My pool is fiberglass and doesn't develop any residue except at the waterline which I clean once per week using a Magic Eraser.
    Vacuum once per week or more depending on the wind, load, etc.
    Clean filter every couple of months depending on pressure reading.
    Check FC daily and add bleach daily. This is the most important thing you can do. Consistency is #1 when using BBB. Letting your FC level drop below your minimum even for a couple of days can cause algae to get a foot hold and take you down the shocking path. Not fun.
    For me PH has never been an issue, so I only check it monthly.
    9K gal. IG Fiberglass Pool
    1 HP Pentair SuperFlo Pump
    240 sqft. Pentair Cartridge Filter
    Non-SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by tcat
    What is your current TA level? Do you have an autofill, or are you having to add a lot of makup water? If you makup (or autofill) water is high in TA, then that might cause TA to remain higher, causing your ph to continue to drift up. With that said, your not having to add an excessive amount of MA. 8 ounces (assuming your TA is at 90 ppm and you have 50 ppm borates...am I right on these?) is only reducing your ph by 0.1. I would wait until your TA gets close to 7.8 (unless you have a scaling problem), then lower it back down to 7.2.
    tcat's Avatar
    May 2012
    Austin, TX
    730
    I have auto-fill. Mostly shaded, so don't lose a lot. Seldom hear water rushing from the float gizmo (unless kids are here).
    TA= 100 My borates are closer to 40. No scaling. Maybe I should keep adding MA until pH is under 7.5. I've never seen it orange, it's always "almost" there, but never real red either.
    DIY chlorine feed
    BBB
