Thread: Jacuzzi air intake have a special termination screen?
    May 2012
    San Jose, CA
    141
    Just had the pool replumbed and the jacuzzi air intake for the jets was upgraded to a 1 1/2" pipe running back to the pad. Previously I had a 1" pipe that just had a couple of 90* turns so the terminating pipe was aimed down and nothing else.
    Now that there is a 1 1/2" pipe, I'm more concerned about something possibly crawling in there to take a nap and clogging the pipe. Anyone have any ideas what is normally done to keep the critters out?
    thanks for any thoughts!
    24k gal 16x38, spa 7x6, Colorscape Caribbean Blue plaster, Pentair Intelliflow, Hayward jacuzzi air pump, Pentair 520 filter, Raypak 336k cu-ni heater, Aquabot Turbo T... pool remodel finished 8/2012.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Jacuzzi air intake have a special termination screen?
    Maybe a fitting plus some aluminum screening? Cut the screen to fit inside the fitting so that when the pipe and fitting are joined the screen is trapped in place.
    Use caution with the screen - it is sharp once cut!
