Thread: Aquarite Aqr T-3 15k cell check cell, low salt error
    Sep 2009
    P. Pines, Florida
    29
    I have an 8500gallon in groun diamond brite pool with a 2y 10moth aquarite aqr arrid climate T-3 15k cell. After all the rain from Tropical storm Isaac I was getting check cell, low salt. My salt reading was 2400 before all the rain. I cleaned the cell in muratic acid 1 to 4 parts as it had some scalling despite cleaning it less than 3months ago. I added 40lbs and had the salt tested at Pinch with a 3300 reading since the system kept erring. I pressed diagnostic for 3 seconds and also tried the salt reading cycle by waiting till the system clicks and pressing the diagnostic 5x. I get no reading and the following:
    1)0
    2)85 temp
    3)30.9
    4)100p or 75p
    5)-0
    6) Al-0
    7)v1.55
    8) T-3
    Does this mean I need a new cell or did I not add enough salt and Pich a Pennies reading of 3300 is off? I called aquarite but I have been working past 5pm and they close so I only had the readings above to give but I was not home.
    Aqua-rite Aqr-x296 T3 15k
    Autopilot Dig-220/Sc-36(replaced)
    Inground pool 8.5k gallons
    Diamond Brite,built 2003
    DE filter
    22,544
    Re: Aquarite Aqr T-3 15k cell check cell, low salt error
    A cell reading low salt when clean is usually a sign that the cell is failing. You can have Pinch-a-Penny test it.
    Sep 2009
    P. Pines, Florida
    29
    That is a great idea. I did not even think of that. I called Luli pools in my area and they told me it tells them wether it is good or bad so I guess that is what I need. I do know that my cell is not big enough for the size pool. Rule of thumb is that the system is twice the size of the pool. Mine is 8500 gallon and the system is 15 which is barely enough. I run it at 70% currently.
    DE filter
    22,544
    Running it at 70% all the time is probably part of the reason it didn't last longer.
    Sep 2009
    P. Pines, Florida
    29
    Update:
    I took the cell to two locations where they have the tester and the cell is dead. I then called Hayward and he confirmed this. I did learn something I did not know and that is that the cell is 3months away from the 3 years and they replace it 100% but some pool stores want to charge a $95 diagnostic fee to tell you that it is dead. Something I already know. There is one place that I took it to and they told me on Tuesday the person that does warranties will take care of it, they just can't replace it since they've had prior experiences where they got stiffed. I do know that part of the problem is that the cell is too small and next time I need to get a 25k or 40k cell to run it at 50% or less.
    DE filter
