Results 1 to 14 of 14
Thread: Dallas Newbie Here - Having trouble with "Reputable PB's"
    I'm having a difficult time with with PB's not itemizing their bids. Is it too much for me to ask them what I'm paying? Anyone run into this? It's very frustrating to say the least. They're showing me numbers but not quantifying them. I ask for numbers broken down and the blow me off. Anyone got any tips for reading bids or dealing with PB's? This is worse than building a home or buying a car.
    Pool/Spa = 15800 gallons; Depth = 3 X 5 X 4; Pentair 520 SF Cartridge Filter; Pentair 400K BTU Heater; Pebble Surface
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Dallas Newbie Here - Having trouble with "Reputable PB's
    Typically an itemized bid should be no problem...seems that many, if not most, builders will supply them with no whining. If it were me, I would tell them an itemized bid is a prerequisite to even be considered. If they won't supply it, then I wouldn't consider them.
    Thanks, I've interviewed 5 PB's and the smaller one's are gladly revealing everything - It's the larger reputable companies that are giving me trouble. I'm hearing all kinds of horse ****.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    You could always black out the competitor information on one of the transparent bids and submit it to them as a guideline of how you would like the budget broken down
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Quote Originally Posted by pktman
    anthony and sylvan broke down their bid for us
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Aug 2011
    Texas
    45
    I'd avoid Hobert after my experiences with their warranty dept.
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
    Please Elaborate on Hobert.... Thanks!
    Dallas
    51
    Robertson provided me with a itemized no problem. Great experience with them so far
    Greg Watson
    15,500 Gallon Freeform IG Martinique Luna Quarts Pool, Jandy CL580 Cartridge Filter, Jandy Stealth Pump, Rainbow 320 Inline Chlorinator and Polaris 280 Pool Cleaner
    Robertson???
    Dallas
    51
    Robertson???
    Robertson Pools in the Dallas area
    Greg Watson
    Thanks - How all did you interview? How did they stack up against the competition.
    Dallas
    51
    I talked to Robertson, Hobart and Venture.
    Robertson wasn't the cheapest of the three but they seemed to have all their ducks in a row. The answered everything very clearly and concise and we just got a great feel from them. They had also done a friend of mine's pool and when he had a small issue with his pump plumbing after a few months they were all over it and responded and got it fixed within two days.
    I highly value customer service and feel that they were the best in our price range.
    Greg
    Greg Watson
    I interviewed several builders too. The one I went with was not the least expensive one, but the one I felt I could work with. We live south of Dallas in a very rocky area. We hit solid rock about 2 feet down. The local PB we used was well aware of what was under the grass here, and had the additional cost built in to his price. Some companies said IF they hit rock, it was $350 an hour. I don't like surprises. Not only that, but when we changed from a weeping wall to a grotto, he only charged us the difference. Some PB added the full cost without giving us "credit" for the wall we nixed. Same with the upgraded plaster.. He just charged us the difference in product and labor. He added decking at his cost when we decided to make the deck bigger.
    I agree with Swampwoman.. make a basic format for your PB to use. Then ask some "what-if" questions. You'll find out pretty quick who you want to work with.
    Good luck, and WELCOME!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    regular digging crews are probably about $300/day (typical daily cost for bobcat/backhoe) and it should only take about a day to dig a typical pool. Rock crews should only cost about $800/day (backhoe with jackhammer + bobcat to haul rock) and should take about 4-8 days depending on the size of the pool. There is additional dump truck cost to remove the rock which is pretty expensive. I would say the hole alone and removal would probably cost in the 4-6K range vs. 300-800 for a dirt hole.
    340/hour is completely ridiculous.
