Results 1 to 8 of 8
Thread: Is there some kind of vacuum hose adapter?
    Aug 2010
    Charleston, South Carolina
    77
    I installed a dedicated vacuum line with a vac-lock fitting like this when I built our inground pool. I've got a basic vacuum head with a 1 1/2" vacuum hose. The hose fits fine into my skimmer, but it's too big for the vac-lock fitting. The vac-lock is 1 1/2" I.D. and the O.D of the hose is 1 3/4. Is there some kind of adapter I can get?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Re: Is there some kind of vacuum hose adapter?
    Bump. I have the exact same problem. I stupidly measured the vacuum opening at 1.5", and ordered 1.5" hose, only to find the hose is way too big.
    Southern WV
    18' Round above ground (52" depth)
    Current baquacil user
    I don't have any experience but I did some google searching and didn't find out squat. Hayward's website is worthless. All I found was in the Hayward Navigator manual that said you didn't use the skimmer cone adapter when you plug the hose into the vac lock. Are you guys using a different cleaner than the navigator?
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Apr 2010
    Buckeye, AZ 85326
    619
    I have a hayward part # V093C. Its the cone adapter mentioned above. You can Bing that part # and see the part. It might get you on the right path. The one I have measures 1 1/2" ID on the small end and 2 1/16" ID on the big end. It's made of a soft rubber.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    I'm wondering if this thing will work:
    http://www.amazon.com/Hayward-AXV092...ayward+adapter
    If it's made to fit inside 1 1/2 hoses, then it should fit right? Looks like this:
    Southern WV
    Aug 2010
    77
    AZ, I found that adapter too. I guess for $5 I'll order one and give it a shot. I kind of wish there was a solution that would allow the locking tab of the vac-lock to still grab the hose like it's supposed to but hey.....if it works!
    I ordered it, and with 2 day shipping it should be here Saturday. I'll post here with my results.
    Southern WV
    Got it today, works fine.
    Southern WV
