Thread: Hayward Super Pump 2hp vs 1.5hp
    Jun 2011
    Austin, TX
    33
    My Hayward Super Pump II 2hp motor just died. It was 8 years old and squealing like a hog in the end.
    My local pool store is telling me that I can get by and save on energy costs by switching to a Hayward 1.5hp motor. They said the output is roughly the same. I have a spa attached to the pool and in total everything is 13,500 gallons. My concern is for the jets in the spa. I do have a separate very powerful blower for the spa jets
    Should I stick with 2hp or take the advice and go down to 1.5? Will I have to alter the running time of the pump? Any other factors to consider?
    13,500 Gallon Plaster IGP
    Hot Tub w/Waterfall
    Aqua Rite SWCG
    A.O. Smith 1.5HP Motor
    Hayward Sand Filter
    Polaris 280 with Hayward 3/4HP Booster Pump
    38,397
    Re: Hayward Super Pump 2hp vs 1.5hp
    What are the listed HP and service factors for both motors?
    You can use a smaller motor, but you may also have to replace the impeller if it is rated for the larger motor. Otherwise you may burn out the smaller motor.
    Likely you would not have to alter the run time as the flow rates are probably pretty close. As long as the pool is staying clean you are fine.
    If you were just going to replace the motor, you should seriously consider a 2-speed motor. Running on low will save a lot of electricity and you can manually switch to high for using the spa (or add a timer to switch speeds automatically).
    Jun 2011
    Austin, TX
    33
    Thank you for the response.
    The exact replacement motor they're suggesting for my Hayward 2hp is an A.O. Smith Eplus 1.5hp. The service factor of the new motor is 1.3. I don't know what the SF is of my Hayward. If there was a label on the motor its since flaked off. It was installed in 2004. I see online that the new ones have a SF of 1.0.
    As for the impeller, the pool store asked me to bring in everything but the wet side of the pump and they'd replace the seal and so forth and have it ready for installation. I'll mention what you said about the impeller.
    Hot Tub w/Waterfall
    Aqua Rite SWCG
    Hayward Sand Filter
    38,397
    Well the new motor is a SFHP (1.5*1.3) = 1.95HP ... so if your old motor had a SF of 1 ... the motors are functionally equivalent and thus won't save you any electricity money, but should give the same flow.
