Results 1 to 9 of 9
Thread: Best product to use for grout repair!
    Mar 2008
    Harrisburg, PA
    13
    What is best product to use for cracks in grout between bottom of coping & top of tile? (above water line) I found sanded & unsanded grout in tubes for bathroom repair but it is not recommended for exterior use. Tried caulk but it doesn't last.
    We live in Pennsylvania so we get freezing & thawing.
    Harrisburg, PA
    18 x 38 IG Gunite/plaster pool
    Oasis form 18,500 gal
    Jandy Aquapure SWG
    30,426
    Re: Best product to use for grout repair!
    There is movement in that area and grout will always crack and probably fall out.
    Polyurethane caulk (not silicone) should work better than anything else.
    I would like to know this as well. We have a few small gaps and would like to fill them before the season is over.
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    Apr 2012
    Klein Tejas
    249
    Isn't that what Deck-o-seal used for?
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Qwaxalot's Avatar
    Jun 2012
    439
    Why polyurethane over silicone (something like DOW 790, for example)?
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    30,426
    I don't know what dow 790 is but I have found polyurethane to provide a more rubber-like texture and to really take a good "bite" into masonry. It is paintable and seems to remain very flexible even in direct sunlight. It is messier to work with but I think worth it.
    38,364
    Quote Originally Posted by Qwaxalot
    I my personal opinion ... silicone is the worst product ever invented
    It does not last outside, you can not remove all traces of it when trying to replace it, and nothing will stick to it (including the new caulk you are trying to replace it with).
    My experience comes from:
    -RV repair shops using it to cover up leaks. The silicone will separate and start leaking again and you can not remove it completely to be able to install the correct caulk
    -The previous yahoo owner (or investment company) of our house that thought it was a good idea to put white silicone around every light switch and outlet plate. Which is now impossible to remove from the wall thus making it near impossible to paint the walls because it does not stick to the silicone
    I think it is OK for use inside in bathroom applications (although again recaulking becomes difficult). But I do not think it is a good choice for exterior application with large temperature deltas or sun exposure ... I think there are better options, although more expensive.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by shazza
    I've used E-Z Patch® 22 at http://www.e-zpatch.com/gallery2.htm.
    It worked for me, just as advertised. I first used it over 2 full seasons ago (like in Sept. 2010) and it has "stayed stuck," stayed flexible, and stayed just as white as the day I applied it.
    Now, I'm no caulk expert. Maybe I could buy the same stuff at HD cheaper, but I wouldn't know what to buy. Maybe I'm lucky that this stuff worked for me as well as it has. But, so far, I'm happy with it.
    After you get all the suggestions you need, please report back and tell us what worked for you.
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Qwaxalot's Avatar
    Jun 2012
    439
    The reason I asked, is because we've been using DOW 790 (UV stabilized, chlorine resistant, with a high modulus of elasticity) for years to caulk between coping and concrete deck. Most applications last 10 plus years. Although I do have to admit, it's a PITA to remove.
