Thread: Algae or something else?
    Two years ago, when opening our inground vinyl pool, we noticed a depression on the shallow end of the pool. We called our local pool company who diagnosed this as a leak and patched it (glued about an 8 inch diameter piece of vinyl over the leak. Last year when we opened the pool, we noticed a rather large black stain around the patch, but we were not able to remove it through scrubbing. This year the stain has gotten bigger and is quite an eyesore. Is this some form of algae, some reaction to the glue or something else?
    Rob G.
    donnaw
    20K gallon in ground pool
    Austin, TX
    Guest
    Very possibly mold that is growing because water leaked under the liner at the leak.
    The mold is presumably on the other side of the liner, so no amount of scrubbing or water treatment will take care of it. If it is indeed on the other side of the liner the only practical treatment starts with replacing the liner, so you may need to live with it for a while.
    IkeRay's Avatar
    Houston, Tx
    154
    What about draining the water down some, and then slicing the liner open in the area where the mold is, take some bleach to it, to kill off the mold, and then re-patch what you just cut away?
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Guest
    You probably can but YOU ARE PUTTING ANOTHER WEAK SPOT IN THE LINER!!!! Sorry for shouting but I wanted to get your attention on that one. Patches are NEVER going to be as strong as an uncut liner and have been known to fail and start leaking again.
