Thread: Tropical Depression Isaac and a lot of water
    Jun 2011
    New Smyrna Beach, FL
    31
    Had to pump the pool down four times in the last 5 days. Between the afternoon storms and Isaac the chemicals are off.
    PH = 7.8 Goal 7.4
    TA 70 Goal 100
    CH 150 Goal 300
    CYA 30 Goal 70
    Salt 2900 Goal 3350
    Put the figures into the calculator. Needs attention. Quick check, what is the order of chemicals to be added? I usually do the acid, salt, and baking soda at the same time. Then the Calcium chloride and finally the Stabilizer. What do you guys think??
    1: 10,000 gals in the ground plaster, Hayward pump SP2715X20 2hp
    2: Aqua Rite Electronic Chlorine Generator / T-Cell-15, Hayward Pro-Grid DE Filter Model DE3620
    3: AquaCal Heat Pump, Astrlite SP0580S Under Water Light
    4: Port PolarisCaretaker, TFTestKit-100
    22,551
    Re: Tropical Depression Isaac and a lot of water
    pH is fine
    TA is fine
    CH is low for a plaster pool
    CYA is low.
    Salt is a little low.
    I'd do CH first, then salt, then CYA. You can do them all at basically the same time.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by jreedich
    PH = 7.8 Goal 7.4
    TA 70 Goal 100
    CH 150 Goal 300
    CYA 30 Goal 70
    Salt 2900 Goal 3350
    I'm assuming your FC/CC is OK and doesn't need attention - is that right? Bama has a handle on this more than I do so I would follow his lead...
    Jun 2011
    31
    FC and CC are perfect. The calculator says to add 222 oz by weight of Calcium chloride seems high to me. Am I overly cautious?
    22,551
    222 oz is what I get too.
    Jun 2011
    31
    Thanks Bama. I sometimes question my own readings.
