Results 1 to 10 of 10
Thread: Heart rate monitor and swimming
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hi folks. I have no idea what category to post this in, so I put it in everything else. I have a heart rate monitor that I wear when exercising. It is the Polar FT7. It is supposed to work underwater (swimming). As soon as I enter the water the watch loses communication from the transmitter (transmitter is on chest strap). I am wondering why this happens. Could it be because of the salt? I have not tried it in a non-salt pool so I do not have any basis for that assumption. If I stand in the pool so that the chest strap is above water, then raise the watch above water, communication is established again. Any ideas?
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Heart rate monitor and swimming
    Quote Originally Posted by GreatCanadian
    Fill the bathtub and test it. That eliminates the salt and other chemicals.
    Jul 2011
    844
    Ok. I will do that. Never thought of it!!
    Bestway SWG
    Jun 2007
    New Jersey
    653
    From the Polar web site FT7 FAQ's:
    Most Polar products can be worn when swimming. They are not, however, diving instruments. To maintain water resistance, do not press the buttons of the product under water. When measuring heart rate in water, you may experience interference for the following reasons:
    Pool water with high chlorine content, and seawater are very conductive. The electrodes of the transmitter may short-circuit, preventing ECG signals from being detected by the transmitter.
    I have a waterproof cordless phone. I can put it under water, and it survives, but it immediately drops any call in progress.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2011
    844
    hmm..interesting. I wonder what they consider "high chlorine content". And is my saltwater pool at 4,000 ppm salt considered seawater? Thanks for that info.
    GC
    Bestway SWG
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    This was posted on Amazon by a user that bought the same FT7 unit:
    "- Water Resistant. I have used this HRM in the pool and the monitoring is relatively accurate when it actually reads the transmitter. I believe the Polar website notes that in some highly chlorinated pools or seawater the transmitter will not be picked up underwater. The pool in my gym is very chlorinated and there were times when the HRM will not pick up my heart rate. But if I just sit still in the water for a minute or so the watch will pick up the signal again. Though this can get annoying if you are trying to swim laps for endurance. The watch still gives me a fair calculation of calories I have burned during my swim sessions. Though the calorie count is most likely lower since I'm not sure how long the watch is not reading my heart rate during times when I am swimming several laps nonstop. I also tried using this in a saltwater treated pool and the moment I went underwater the transmitter does not work at all. So I'm guessing that this HRM will not work if you are swimming in the ocean."
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jun 2012
    Mint Hill, NC
    2,589
    I guess you can try wrapping that part of your arm in plastic wrap to see if this helps.
    May 2012
    Montville NJ
    545
    Quote Originally Posted by UnderWaterVanya
    My guess, and it is only a guess, is that it has to do with the tranmission of the radio waves between the HRM and the watch through a medium that has a lot of free ions in it (Salt water Na+ and Cl-, or just Cl-). Wrapping the watch and/or HRM is not going to help, you need to clear up the transmission path. I know people that when they are training for triathalons, and doing ocean swims, will put the watch under their swim cap. That way it is out of the water and can pick up the GPS singnals. However, if you did that, your HRM is still in the water.
    Sorry - I really do not have a solution for you.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Apr 2010
    Fleming Island, FL
    431
    Quote Originally Posted by phonedave
    The problem is actually that the HRM shorts out in the salt environment due to the high conductivity of the water. The communication between the HRM and watch is possible since the transmission frequency of 5kHz is well within the range of radio wave transmission under saltwater. There are models of HRMs out there that are made for saltwater that deal with this issue.
    Carlos
    May 2012
    Montville NJ
    545
    Quote Originally Posted by benavidescj
    If that is the case, then waterproofing the HRM should do the trick. Looking at mine, there are no exposed electrodes, so you should be able the pot it in something. That would make changing the battery a PIA of course.
    -dave
    Zodiac Wahoo
