Thread: How to connect hose to Vac Lock fitting?
    Aug 2010
    Charleston, South Carolina
    77
    I installed a dedicated 2" vacuum line when I built our inground pool. I just purchased and installed a Waterway Vac-lock fitting like this. But the 1 1/2" hose that came with my vacuum head won't fit it. The hose fits fine in my skimmer, but I want to use the dedicated line. Is there a connector of some sort that I need?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: How to connect hose to Vac Lock fitting?
    Quote Originally Posted by mlawrence17
    Is it too small - too big or what? The 2" fitting sounds too big for the 1.5" hose. I wonder if you need to get another hose or adaptor to allow the 1.5" hose to fit.
    Aug 2010
    77
    The hose is too big for the vac-lock fitting. Not to mention that the collar on the hose sticks out farther than the little locking tab on the vac-lock fitting which is supposed to grab the ribs on the hose to prevent it from coming out. The hose that came with the Kreepy Krauly fits in the vac lock fine, but not the one I use with vacuum head.
