Thread: NEED HELP!
    Dallas, Texas
    3
    NEED HELP!
    Hi Im new to TFP but I need all the help i can get. Three of my support poles have fallen off the pavers and the vinyl straps that were attached to the pool that held the support poles have busted, Im draining pool now does anyone know if they are rapairable or if once ive drain and releveled pool would the poles still have the same support without the staps please help I need all the help I can get
    Intex 16 x 32 x 52 metal frame pool
    SWG
    7/2012
    22,551
    Re: NEED HELP!
    Welcome to TFP.
    There have been a thread or two where people have used rope or ratchet straps to repair a broken pool strap. Either should work pretty well.
    Dallas, Texas
    3
    Re: NEED HELP!
    Yes Ive seen that done but only on round metal frame pools which hold the poles close to the pool. My pool is rectangular and the poles are at a 45 degree angle and the straps were attached to the botom of the liner then held by the support poles anyone with a rectangular intex metal frame pool have any advice
    SWG
    7/2012
    Jun 2012
    MA
    347
    Re: NEED HELP!
    Do you think that you could repair the straps that broke? Possibly with glue and stiching? Those straps look like they hold back a lot of force and just the fact that they broke shows the forces involved. It is probably time for a new pool.
    Apr 2012
    SW Ohio
    456
    Re: NEED HELP!
    how long ago did you buy it? if it is within 90 days intex will replace the liner.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Dallas, Texas
    3
    Re: NEED HELP!
    i purchased june 26 2012 i will call and find out thanks
    SWG
    7/2012
