Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Algae; not sure what to do
    May 2012
    Dallas, Texas
    47
    7.5 FC (just added 96oz. to bring it to 10.5)
    7.5 pH
    100 TA
    CYA ?
    My pool has has had light green film on bottom for about two weeks. I think I let the FC go below 3 ppm for a couple of days and did not vacuum for 2 weeks. I brought the FC up to 10 as soon as I saw a light green area (two weeks ago) and ran my kreepy krawly. The water became cloudy. pH was at 8.0 to 8.2, I bought ph down from box store to get that back in order. I began running the vacuum 3 to 5 hours a day every day since last Thursday (6 hours on Saturday and Sunday). Raised FC to 10ppm on Friday and kept it there Saturday, it fell to 9.5 Saturday evening so I added the recommended amount on the pool calculator to bring it back to 10 ppm. I ran pump non-stop from Friday night to Sunday night. This afternoon (Monday) it was at 7.5 and a lot of green on the bottom. Kreepy Krawly began sticking to bottom today, I have never seen that, but it tends to miss some spots. It seems to be getting worse, not better. I'm at a loss as to what to do. Pool has been crystal clear since June by keeping ph, TA, FC and CYA at recommended levels. I'm thinking I need to get in daily and scrub bottom and sides.
    A green cloud comes out of the return when pump is turned on. We have had a good amount of rain here in North Texas for a couple of weeks now. Does that contribute to the algae?
    Any advice is much appreciated.
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 ½ hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae; not sure what to do
    We/you need to know the cya level to move forward with the shocking process that your pool needs.
    May 2012
    Dallas, Texas
    47
    Thanks linen.
    I'll check it in the morning. Water is relatively clear then.
    TF 100 Test Kit
    Apr 2012
    SW Ohio
    456
    the reason it is getting worse not better is most likely because your not at shock level per your cya level thus letting the algae grow, please post up a full set of test results so we can help you get your pool sparkly clear again, also the ph test will show falsly high for fc >10 ppm i would let fc drop below 10 ppm so you can get a accurate reading on ph and lower it to around 7.2 prior to starting the shocking process...jmo.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    May 2012
    Dallas, Texas
    47
    Updated test results: 12:15pm Tuesday
    FC 8
    CC > .5
    pH 7.6
    TA 100
    CYA 40
    CYA test - as I slowly add drops per instructions, the dot at the bottom is gone briefly at 60. Less than 1 second later it is visible. It disappears and stays gone at 40. Am I reading this correctly at 40?
    TF 100 Test Kit
    22,553
    I would say it's probably close to 50. But anywhere between 40 & 50 is fine to use.
    May 2012
    Dallas, Texas
    47
    JasonLion posted that a pool should be at 7.2 to 7.4 pH before beginning the shock process. At 8 ppm FC can I trust my reading of 7.6 pH and begin to bring it down or should I let the FC drop more and take another pH reading?
    With a CYA value of 50, the pool calculator says my shock level is 16ppm. A value of 60 the shock level is 18ppm. Is it ok to go high?
    How long do I keep the pool at shock level?
    TF 100 Test Kit
    38,528
    pH test is affected once the FC > 10ppm. Lower you pH a bit before starting the shock process.
    From the more aggressive Chlorine CYA Chart, shock level is 20ppm for a 50ppm CYA. You will not damage anything if you stay below the mustard shock level listed in the calculator (if that is what you are worried about). Just pick something between 16ppm and 20ppm as your target.
    You stay at shock level until you pass the 3 test to stop: Shocking Your Pool
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Toomchfun
    The pH test is accurate with the FC below 10. So, yes, trust your test.
    Shock level for CYA of 50 is betweel 16 (Pool Calculator) and 20 (CYA/Chlorine Chart).
    Maintain the shock process until you meet the three criteria that show you are done. See red lines in my sig.
    ETA:Jason is fast.
    You're done SLAMing when:
    30,432
    That is the answer that eludes many, many newbies and that answer is the key to shocking correctly.
    Read the article in Pool School on How to shock your pool and you will find you need to keep the FC high much longer than you think.
    YOur pH result of 7.6 is close enough....I would shock without lowering the pH. It is also a valid reading you can trust.
    Don't get your FC too high. That's why there are guidelines. 16ppm is fine but do not assume you can put in an unlimited amount of FC. Use 16 as your target if you like but retest often so you can replenish FC back to 16.
    (Jason and Butterfly are BOTH fast)
    May 2012
    Dallas, Texas
    47
    Thanks for all the feed back! A few more questions before I begin.
    My AGP has no deck. How do folks brush while at shock level without getting in? Is it safe to enter?
    How many minutes do I backflush and rinse my sand filter and how often during this process? Usually I go until the water is clear, is that the same for the shock process?
    Should I run my Kreepy Krawly vacuum during this process?
    TF 100 Test Kit
    38,528
    Brush as well as you can ... actually getting in is not really a problem ... since you will not be putting your face in the water. We do not typically recommend getting in the water when FC is greater that shock level and you can not see the bottom (if you slipped under the water ... no one would be able to see you).
    You should backwash when the filter pressure goes up 20-25% of your clean pressure. Then backwash until the water is clear. Do you have a multi-valve? If so some people alternate between backwash and rinse a few times.
    There should not be a problem with running the vacuum during the shock process.
    May 2012
    Dallas, Texas
    47
    I'm not sure what a multi-valve is. The top of the filter has the options with a notch at each one. I turn the pump off, push down on the lever and turn to the desired option, then turn the pump back on.
    TF 100 Test Kit
    38,528
    That is a multi-valve. Some filters only have a push/pull valve with only the backwash option.
    May 2012
    Dallas, Texas
    47
    This is my valve[attachment=0:3fylp8fn]untitled.bmp[/attachment:3fylp8fn]
    TF 100 Test Kit
    38,528
    If it has a rinse/clean option, then alternating between it and backwash a couple times will clean things out a little better.
    Jul 2012
    Riverside, CA
    51
    May I please ask a related question here? Does it mean it is not safe to put your face in the water when FC is greater than shock level? I did that multiple times while shocking my pool.
    I yet to clean my lights. Shall I let FC come down and then do that? Thank you!
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    38,528
    Quote Originally Posted by xiaobulu
    Ugh ... I never should have said anything. It is not so much the high FC that is a problem ... but if you have higher CC since you are in the shock process, they could be more irritating. Or there could be other things in the water that required the shock process.
    Easiest to just say ... safe when FC is below shock level, CC is not more than 0.5ppm, and you can see the bottom ... Because that implies that you have completed the shock process.
    Jul 2012
    Riverside, CA
    51
    Alright. Thanks!
  20. Back To Top    #20
    May 2012
    Dallas, Texas
    47
    Tuesday evening:
    FC 8 ppm
    Cleaned skimmer basket
    Cleaned lower basket
    Backflush and rinse
    brushed sides and bottom of pool
    Raised FC to 18.5 ppm
    Wednesday 7:00am
    FC 18 ppm
    water cloudy
    Wednesday 12:00 noon
    FC 13 ppm
    Raised FC to 18
    Wednesday 6:00 pm
    FC 13 ppm
    7:00pm
    FC 20.5 ppm
    Water looks better
    Ran vacuum 7:00 pm to 10:15pm
    Pump running non-stop
    TF 100 Test Kit
