Results 1 to 7 of 7
Thread: Any suggestions for TS/hurricane pool prep?
    acadianarose's Avatar
    Lafayette, Louisiana
    28
    Issac is on the way. We are expecting a lot of rain and probably power outages. I was planning on adding extra bleach before hand. Any other suggestions?
    Also, do I need to worry about all of the water that will end up in the sump pit during the storm? Of course, we will not be able to run out during the storm to pump it.
    Thanks for your help.
    Linda
    12 x 23 Fiberglass IGP Built 2012
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    Pentair Clean & Clear Cartridge Filter
    38,290
    Re: Any suggestions for TS/hurricane pool prep?
    See: hurricane-advice-needed-t52605.html?
    Or you can do a search at the top or bottom of the page.
    Apr 2012
    SW Ohio
    456
    we are all praying for you Linda hopefully the good lord will spare your pool....
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    28
    Quote Originally Posted by fast1971chevelle
    Me too. We just finished it last weekend!
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    Bjarni's Avatar
    May 2012
    Albuquerque, NM
    51
    Good luck. Hope your family is safe!
    9K gal. IG Fiberglass Pool
    1 HP Pentair SuperFlo Pump
    240 sqft. Pentair Cartridge Filter
    Non-SWG
    Apr 2012
    SW Ohio
    456
    beautiful pool Linda
    28
    Thank you! We worked very hard over the past few months.
    And I am happy to report no damage to my pool (or home) other than about 2 inches of leaves at the bottom of the pool.
    Thanks for everyone's help.
    Linda
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
