Results 1 to 8 of 8
Thread: Pentair IC-40 Too Big
    I have run into the issue that my IC-40 SWG is too large for my pool. We had an extremely hot summer and I did not have to increase the SWG by 20% the entire time. I do keep my pump on 24/7 on low (it's a two speed) and would like to continue to do that in the future. I would like to figure out a way to make my SWG only run 10% without having to get an easy touch or intellitouch -- anyone know an easy way to do this on the SWG without changing the pump time and/or getting the easy/intellitouch?
    Thanks!
    17'x36' Freeform (Omni/Gemini shape) Polymer Vinyl Liner Pool; Made by Hydra Pools; 6' Water Depth; Cantilever Concrete Stamped Coping; 8' Radius White Step; 8' White Cozy Cove with 6 Jets; 1.5 HP Pentair Whisperflow 2-Speed Pump; Pentair Clean and Clear Plus 420 Cartridge Filter; Kreepy Krauly Legend Pool Sweep; 2 Skimmers; 4 Returns; 2" Rigid PVC; Pentair 5G LED Light; Pacific Ultra Mesh Safety Cover; Pentair Intellichlor IC 40; 3 Deck Jets
    38,242
    Re: Pentair IC-40 Too Big
    Easiest solution would be to get another timer and run the power to the SWG through it ... then the SWG would not be generating all day.
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Why do you run the pump 24x7? Do you have an excessive amount of debris falling into the pool?
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Come on... you and I know the easiest solution is to increase the bather loads! Throw some wild parties and toss a dog or two into the pool!
    Just kidding!
    I think the 2nd timer option is a very good option.
    To be honest, I just don't want to have to mess with it... I was hoping there was a way to program the ic-40 to only run 10% of the time, but I guess that's not an option
    38,242
    Only 3 options (well 4 if you count UWV's idea ):
    1. Reduce pump run time (no real reason to have to run 24/7)
    2. Add a timer on the SWG
    3. Buy the controller to get more control over the % settings
    Jun 2012
    Mint Hill, NC
    2,589
    My option has these advantages:
    • Low cost!
      Fun!
      Able to be implemented immediately - no delays!
    But it has these downsides:
    • Hard to end - when will those freeloaders leave!
      Fun becomes work eventually
      Doesn't solve the problem long term...
    Sigh... I guess there are only 3 legitimate choices after all.
    Thanks guys... sounds like I'm going to use a timer for the pump/SWG... Appreciate the help!!
