Thread: Kit arrived and first test complete
    Pool is currently clear/blue in color and slightly cloudy.
    I purchased a TF-100 Test Kit.
    Results are below.
    FC: 9.5 ppm
    CC: .5 ppm
    TC: 10 ppm
    TA: 60
    CH: 50
    CYA: 80 ppm
    Should I do a partial drain to lower CYA? Suggestions?
    Thanks.
    Chad
    Chad
    Summer Escapes 15' x 42" Quick-Set Ring Swimming Pool installed June 2012
    3200 gallons, cartridge Filter, Above ground, vinyl
    Filter Pump RP800 780 G.P.H.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Kit arrived and first test complete
    How long will your season last? Do you drain any water over the winter?
