Thread: polaris 165 mid chamber part
    My polaris 165 started going in one pattern only with the radomizer ball staying in one outlet only. I found the the spring seal in the mid chamber worn down. I replaced the center chamber of the piston unit and it now works as it should. The only thing wrong with my original center chamber is the black spring reinforced seal, it's 1.25 inches diameter. My problem is knowing where to order the seal. Does anyone know of a place to order a spring reinforced seal??? Hate to replace the center chamber a second time because of one little seal worn down (read this as cheap or not wanting to waste good parts without a good reason!).. If anyone can point me toward a company to order a spring seal from I'd appreciate it....
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: polaris 165 mid chamber part
    Hello! I checked and Polaris doesn't sell the part separately. You may be able to find a generic replacement just be careful of quality. I couldn't find anything but let me know if you do!
    Thanks Christian, I'll keep looking. I have the new mid chamber but i just hate to trash a good part cause of one little seal.May have to order an assortment of seals and compare quality and material to the orginal.
    Christian's Avatar
    Jul 2012
    304
    You can also often cut your own seals if you get some rubber and use the old one as a pattern.
