Results 1 to 8 of 8
Thread: TA question
    TA question
    Had a higher ph (7.9) and a low TA (70) so I raised the TA via 7 lbs of baking soda first
    Then lowered the ph via muriatic acid (which also lowers TA)
    So I aerated the water via spa jets to keep the TA from falling.
    Ph was 7.5 and TA = 100 after 24 hours, which is ideal I believe.
    Should I aerate regularly to keep the TA around 100? How do you decide when to add baking soda vs. aerating ?
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA question
    What is your chlorine source? If it is bleach/liquid chlorine, then our recommended level is 70-90 ppm TA. See: http://www.troublefreepool.com/pool-...mmended_levels
    30,431
    Re: TA question
    You have that a bit confused.....
    TA up - add baking soda
    TA down - use the acid-aeration method as described in Pool School
    Re: TA question
    ok, makes sense, thanks for clearing that up.
    so how often should you aerate, only when your PH is too low and should you always try to aerate instead of adding soda ash?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA question
    If really depends on what your TA levels are. See the "raising ph" part of this pool school article: http://www.troublefreepool.com/pool-...pool_chemicals
    30,431
    Re: TA question
    I think you are missing the point still.....aerate when you need to lower TA.
    The simplest way to remember this often confused idea is....
    pH up - Borax
    pH down - Muriatic acid
    TA up - baking soda
    TA down - aeration and acid.
    Re: TA question
    problem is I couldn't find my specific topic in TFP so I just googled the question and there is so much conflicting information when outside of TFP.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: TA question
    Quote Originally Posted by jp4120
    Did you try to limit the google search to TFP? That can help when the built in search is too limited.
