Results 1 to 9 of 9
Thread: upgrading my pump and filter
    Jul 2012
    Southern California
    21
    I have a intex 20' x 10' that i purchased at costco. Comes standard with a 14" sand filter pump and its just not doing the job. Im ready to upgrade but having trouble under standing some things. Manual states maximum flow rate is 1600 gph and the effective filtering are is 1.1 square feet. Is that acurate for a Intex pump?
    Pool store recomends A Hayward Micro star filter system. Hayward Says the filter has a 1200 gph capacity and the motor says 40 gpm for its horse power. Whats that mean? Would this be considered a up grade for what i currently have? Please advise
    Intex 20x10...Intex sand filter...Intex3000gph TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: upgrading my pump and filter
    Welcome to tfp, drnava99
    Quote Originally Posted by drnava99
    That sounds right. For your pool, that filter is correctly sized.
    What problems are you having?
    Your current sand filter is better sized for your pool then this cartridge filter. We would recommend a minimum ~80 sq. ft. cartridge filter for your pool, and the largest Micro-star is 55 sq. ft.
    Jul 2012
    Southern California
    21
    The vacuming is horrible...Have to go over the same area a couple times to pick up the debris from the bottom.
    Don have exact numbers from water testing but pool store said it was good that May b the pump just isnt turning over the water. It appears to be cloudy, More on the bottom than the top. Thanks again
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The 1600 can vacuum, but does not have the force that some bigger pumps have. Have you backwashed it lately?
    Jul 2012
    Southern California
    21
    I have backwashed bout 2 days ago..would it b wise to use that Hayward pump with my sand filter?
    Phoenix, AZ (East Valley)
    28
    If you really want to change it out I'd recommend the Intex 2650gph sand filter.... it has more than enough power to suck up anything. My Hayward "Wanda the whale" automatic cleaner picks up 1/4" to 3/8" pebbles when teamed with the upgraded pump. Probably the best "bolt-in" fit (no need for adaptors etc) for a no-hassle install and it runs under $200 (check Amazon)
    -S
    Phoenix, AZ east valley area
    • Intex 16' x 48" Frame AGP (5000 gal)
    • Intex 2650 GPH Sand Filter
    • Floaty Type Chlorinator
    • Intex frame-mount skimmer
    • Hayward Wanda the Whale Cleaner
    • EcoSaver Solar Pool Heater
    Apr 2012
    SW Ohio
    456
    the 2650 would be a much better fit for your pool like stated above but the over the wall skimmer that intex uses leaves alot to be desired when it comes to vacuuming your pool, i would suggest not using it to vacuum just use the blue adapter and hook the vac straight to that and to fill the vac hose put it over the return to fill the hose so you don't lose the prime on your pump. i installed a thru wall skimmer and a hayward pump on mine and vacuuming is a breeze now.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Jul 2012
    Southern California
    21
    I tried it with out the skimmer and oh boy what a difference. Thanks a lot.. do you know why the hayward motor states 40 gpm on the label under Horse power appose to others that have a Just a number with out the gph? Also on your signature, what is "1 inch sch 40 pvc" mean?
    28
    Yup, going directly to the blue adaptor is the way to do it.
    It's all about marketing - using GPH instead of GPM makes the number look bigger. 1 GPM = 60 GPH and thus, 40 GPM = 2400 GPH.
    Schedule 40 & other schedules (Schedule 80, 120, etc) are standard pipe ratings. A sch 40 pipe is rated for 140psi while sch 80 pipe is rated for 200psi.
    The pics below show 1.5" sch 40 PVC pipe/fittings that I use on my pool (the hard piping, not the flexible Intex hoses)
    -S
