Results 1 to 7 of 7
Thread: Water escaping through backwash line when in filter mode
    When my pool is in normal filtering mode I have water escaping through my back wash line. It just started doing this. At first, I could backwash, switch back to filter and water would come out of the back wash line as well as water recirculating into the pool and also it would send debris into the pool. But if I "rinsed" after back wash it would filter and return properly. Now it is releasing water through the backwash line whether I rinse after a backwash or not. I assume there may be a problem with my multiport valve. Suggestions? Thanks. J
    30000 gallons, inground, plaster.
    2ft diameter 300lb Hayward Pro Sand Filter S2442 model
    TF-100 Test Kit
    1 1/2 HP Hayward Super II pump model: C48L2N134B1
    Standard Polaris pool vaccum
    Hayward variflo valve
    mesh cover over the winter
    Northern Virginia
    38,516
    Re: Water escaping through backwash line when in filter mode
    Open up the multi-valve and check the "spider" gasket inside ... likely damaged and leaking. Some are just a gasket and newer ones have the gasket bonded to a plate that is replaced with the gasket.
    Jason, I have had to slowly learn how to do different things on my own to my pool pump, etc., like changing the sand myself, and changing out the capacitor on my pump motor, so pardon me if I sound a little uneducated when I ask the Hows.
    To open up the multi-valve, is it just a matter of unscrewing the top plate to get to the spider valve?
    Thanks so much.
    TF-100 Test Kit
    Northern Virginia
    38,516
    No problem. Yup, should be as simple as removing the ~8 screws on the top.
    Make note of the correct orientation of the top before you remove it (maybe take a picture). There should be some guides or indicators, but it is not always obvious and if you put in on wrong it can lead to all kinds of odd behavior.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    On most port valves there is a odd nodule that lines up so you don't have to worry about putting it back wrong. Unless yours is the new style that has the gasket bonded to the key assembly, then you can mess things up.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks Jason and Kevin. So the spider gasket should be something I can buy at my local pool store? Leslie's or Aquarama in my case.
    TF-100 Test Kit
    Northern Virginia
    38,516
    For a premium, but yes. Although if it is like my Leslie's, they have to special order everything.
    Posted from my Droid with Tapatalk ... sorry if my response is short
