Results 1 to 8 of 8
Thread: trouble with my automatic pool sweep
    I recently bought a used pool with all the trinkets that came with it including an automatic pool sweep...
    My pool sweep is a DIRT DEMON not a DIRT DEVIL... The previous owner said that I needed some contraptions to hook on the hose, he had evedently lost them, but looked in his cleaner box and there was one spare in a closed bag... I only have 1 on a total of 3 or 4 I think...
    Here are the problems that I have... The pool sweep ALWAYS does the same pattern over and over, leaving dirt in some spots...
    I think it might be due to the fact that I don't have the "hose weights" because the previous owner lost them, I have one thow, I installed it smack in the center of the hose lenth EX: I have 8 x 3 foot tubes so I clipped the fitting on the junction of tube 4 and 5...
    OR
    I noticed that I have 2 movable floaters on the machine it's self could my floaters be in the wrong position... I can't find or have the owners manual so it's trial and error...
    what could be the problem... I leave my cleaner on for 12 to 24 hours and still no success in a clean bottom...
    by the way I always remove the lader even if my cleaner has the contraption for the pool lader I don't want to take the chance...
    Here is the link to my machine...
    http://www.familyleisure.com/Discoun...c-Pool-Cleaner
    You actually see the yellow fitting on the white hose that I am missing, I think they are hose weights because when I threw the ONLY ONE I have in the pool it sank
    Re: trouble with my automatic pool sweep
    My Polaris manual says to adjust the floaters so that the hose stays on the surface, not dipping low in any place. I also pushed them back from the cleaner itself as my Polaris stays too high too often. The shallow end is maybe 4 feet and I have the first float at maybe 5 feet from the end, maybe 6 feet.
    Sorry I cannot help on your particular cleaner type.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    The link isn't working for me - is this it?
    Quote Originally Posted by UnderWaterVanya
    yes this is the one sorry for the broken link
    anyone ?? please
    Jun 2012
    Mint Hill, NC
    2,589
    Kreepy KraulyŽ, Kruiser is similar:
    http://pentairpool.com/pdfs/KreepyKruiserOM.pdf
    See if this helps - they use weights and floats also and operate in a similar method.
    Jun 2012
    Mint Hill, NC
    2,589
    Ugh - just realized I posted DIRT DEVIL data in this post - sorry.
    Jun 2012
    Mint Hill, NC
    2,589
