Thread: High PH low TA
    High PH low TA
    I have high PH 7.8+ and low TA 50ppm according to the test I did today. I just want to make sure I am doing the right thing...adding muriatic acid to lower the PH and Sodium Bicarbonate to increase the TA. Does that sound right?
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: High PH low TA
    Quote Originally Posted by jamie1983
    Yes.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: High PH low TA
    yep...baking soda will increase the TA with a minimal effect on the pH.
    Re: High PH low TA
    Thank you, I thought that was right I just wanted someone to confirm it. I added the muriatic acid today, will hit it with baking soda tomorrow.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: High PH low TA
    Just note that if you raise the TA you increase the rate of pH rise so you may not want to raise it very much (assuming you are not using a net acidic source of chlorine).
