Thread: Basket o'ring leak?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Basket o'ring leak?
    Have a Whisperflow pump, been trying to fix air problem for weeks. New o'ring. Basket water level drops 50% in 8 hours. I've cleaned and tried silicone grease, and teflon plumbers putty. After pump stops I can see a bubble about every 10 seconds go to the top of the lid. The pump primes in about 30 seconds, should I worry about it? Anything else to try? New lid?
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    22,553
    Re: Basket o'ring leak?
    There have been a couple of threads where there turned out to be a hairline crack in the basket lid.
    Are you sure the lid is where the leak is?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Not sure where the leak its, but does look like the bubbles come from the edge of the lip. Could be coming from below I suppose. Any dye I can spray on to see if it shows a crack up?
    DIY chlorine feed
    BBB
    22,553
    Careful inspection under bright lights is how the previous ones were found I believe. There is dye tests that you can buy, but they're probably more expensive than a new lid.
    Qwaxalot's Avatar
    Jun 2012
    439
    In the meantime, pull out the pump drain plugs and examine the little o-ring. They often develop hairline cracks that will show up as a tiny bubble entering the pump.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
