Thread: Pink Algae need help
    I'm just starting to see some pink algae. Some at the deep end and some at the stairs. The water is nice and clear. Filix
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    22,553
    Re: Pink Algae need help
    The answer is chlorine and performing the proper shock process until you pass the OCLT.
    Thankyou Dave. But whats the OCLT?
    22,553
    Overnight Chlorine Loss Test. Click the link in my signature or search for it in Pool School.
    Thankyou Dave. Couple more questions. Does it hurt your solar cover to cover the pool when the chlorine is so high? And should I keep the pump going all night? Thanks.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by filix
    We would recommend leaving the cover off at least during the day so that the sun's uv light can help with the shocking process. You can put the cover on night, the shock levels we recommend will not shorten the solar cover life much (unless you are shocking for a long time...i.e. many weeks).
    I would, especially with a sand filter, since that will speed up getting the dead algae debris out of the pool.
