Thread: Stains ? What causes them & how to eliminate?
    Jun 2012
    Lafayette, Ca / USA
    260
    When we took over this pool in our new house, the previous owner had a pool service. They had a PoolRx metal thing in the pump's filter area. Based on what I read here, not a good thing to use so I removed it. We have come to notice that there are some small (1/4" - 1/2") stains on the pool floor & walls. (they were likely there before I removed that PoolRx thing; but we just started noticing the stains.) I tried rubbing them off, thinking they were just dirt, but they are definitely brown stains of some sort.
    What caused that? Can they be somewhat easily removed? Is there some 'adjustment' to my checmicals that is needed?
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    38,524
    Re: Stains ? What causes them & how to eliminate?
    try using some vitamin c on the stains, if they fade that would confirm it is a metal stain.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Mar 2007
    San Rafael, CA USA
    12,082
    PoolRx has copper so the stains are likely copper stains.
    Jun 2012
    Lafayette, Ca / USA
    260
    How do I apply the Vitamin C ? what is the process & how much do I use? And if it IS a Copper stain, is there any other way to remove it?
    38,524
    One method is to get some of the vitamin c tablets and break them up and put them in a sock which you just set on the stain for a little while. This may work if they are small spots.
    If you confirm they are metal stains, there are while pool treatments. See the article in Pool School.
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks !
