Results 1 to 10 of 10
Thread: Looking forward to owning my pool again
    Jul 2012
    River Plantation, Conroe, TX
    4
    Hey folks....
    After a difficult year and a half of financial ups and downs, the time had come to get my pool back. So glad I stumbled upon this site and the BBB method. What we had here was our own swamp complete with the frogs, a snake, bugs......and just filth.
    Money still tight, but have a Taylor K-2006 on its way....wanted the TF, but found the Taylor for under $53 shipped.
    For the past week and a couple days, been bombarding the pool with bleach. Got some test strips because I figured at least it was some kind of reading, primarily looking for a CYA level and the pH.
    Strips had CYA at 30-50 and pH at 7.5. Those strips only read FC to 10ppm. Luckily, I have a family member at Grainger......she got me strips just for FC that read to 25.
    Been keeping the FC between 20 and 25. Took exactly one week for the water to be crystal clear while cleaning the filters 3 times.
    As of now, water clear...brushing daily stirring up what appears to be grayish dead algae. Going to keep the FC at that shock level until the brushing stirs up nothing or until the kit arrives anytime between Monday and Wednesday so my wife and I can learn to use it properly.
    And yes, the pool has been running constantly only shut down to empty the pump basket and to clean the filters. May my light bill this month be slightly forgiving.
    Once the kit comes in, I'll give full readings and start looking to what else I need to get in line for some late summer pool enjoyment.
    Loving this site and all the info so far....
    22,000 gallon IG free form, Pebble Tec, WhisperFlo WF-24 C 1hp pump with AO Smith 2hp motor (3450 rpm), Purex Triton Clean&Clear Plus CC320P cartridge filter.
    Taylor K-2006 test kit
    22,550
    Re: Looking forward to owning my pool again
    Welcome to TFP.
    Aug 2011
    Central Valley California
    121
    Welcome. Glad you got your pool back.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    Quote Originally Posted by Mappy
    Hey folks....
    keep in mind that the taylor 2006 only has enough CYA reagent for about 3 or 4 tests I think. When you run the test if you arent sure of the result just pour the test mix from the test tube back into the mixing bottle and drip it back into the test tube.
    You also dont need to test CYA regularly. I havent tested it in maybe a month since we had a bunch of rain.
    You can do an initial test, if you need more CYA you can add it, wait a few days, then test again. After that it will likely be stable
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Jul 2012
    4
    Ok.....got my test kit....
    First readings (with a tad bit of double-checking):
    FC 6
    CC .5 or less.....barely pink but 1 drop cleared it instantly
    pH 7.3 Going to add a little borax....I want that 7.5 sweet spot
    TA 90
    CH 310
    CYA 37 Going to throw some granules in a sock....looking for about 45
    Kids jumped in for the first time in a loooooong time after school.
    We were amazed at how our daughters hair looked and felt and how their eyes weren't all bloodshot.
    Truly loving BBB.
    Thanks for allowing me to stumble upon this wonderful info!
    30,421
    Good numbers. Don't be in a rush to add that borax. pH has a natural tendency to drift upward on it's own.
    Jul 2012
    4
    I was thinking that....going to wait and see how it does over the next couple of days especially with having swimmers in it again.
    Butterfly's Avatar
    South Carolina
    10,045
    Good job Can we see a pic?
    +1 on duraleigh's recommendation for the pH. The kids will aerate and raise the pH for you
    You're done SLAMing when:
    Jul 2012
    4
    Hey guys....is there an easy way to pot a pic?
    Most of us use a hosting service such as Flickr or Photobucket.
    Once you have the pic hosted, use the image's url and the IMG tags to post it.
    If you need a tutorial, just ask.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
