Results 1 to 7 of 7
Thread: Pump without capacitor
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    My pump, after about a week of inactivity, will not longer start. However it will hum when powered on.
    After reading many of the posts on these threads I'd like to check the capacitor. The pump (an older Hayward power flo) just has a cap on the back. No top bulge. It seems in the past I tried to find it when it wouldn't start and when I removed the cap could not locate it.
    I tried tapping on it (worked once before). This time no luck.
    Is there such a thing as pump without capacitor?
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Re: Pump without capacitor
    Might be a centrifugal switch on back of motor
    Look for springs conected to a metal plate
    Some times this gets stuck in the out position
    Try to flip in toward motor ahaft
    Google centrifugal switch should get a picture of it
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Re: Pump without capacitor?
    The white v-shaped plastic with the springs.
    I can push it down (unplugged) and it spings back up.
    When I power it on it does not move at all.
    It doesn't sound safe but can I push the switch down with a wooden stick to see if it turns the impeller?
    22,553
    It's not very safe, but you can close the contacts with a stick. However, they should be closed when the pump isn't running anyway.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Back and running!
    I used the wooden end handle of a small rubber mallet (holding it by the rubber head) to push the contact down. The pump rotated sluggishly and I let go/repeated a few times and voila! The middle contact area receded back to its original position once the "centrifugal" part kicked in.
    If I can just get by the rest of this summer I'll be good to get a new pump next year (this one is very old).
    It seems to run a lot quieter now...maybe keep?
    Thanks folks! Saved again by TFP!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It's easy to change out the motor if the pump portion is working fine.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Quote Originally Posted by Onslow
    Yes, there are a few designs that don't use start or run capacitors.
    Single Phase Motors
    Mark
