Results 1 to 10 of 10
Thread: Green Algae with plenty of chlorine present
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Greetings,
    When my pool warms up in the summer I get small amounts of green algae forming, primarily in areas where the Kreepy Krauly can't reach (corners, steps, etc). I have a saltwater pool and there is plenty of chlorine always available but I find myself brushing back algae more often than I would like (2x per week). The water is crystal clear and there is not a LOT of algae, but I am wondering how it grows in the presence of chlorine.
    Note that this has only begun now that my pool temp is consistently above 80 degrees this summer. It had never shown up in colder temps.
    Perhaps this is normal and it is easy to brush off the vinyl surface, but I am wondering if I am doing something wrong.
    Thanks
    Tom
    21K Gal Vinyl In Ground with block wall sides (Self Built with help), Pentair Easy Touch controller, Pentair Intelliflo pump, Intellichlor salt system, Clean and Clear Plus filter, SR Smith Typhoon Slide
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Green Algae with plenty of chlorine present
    Do you have a test kit? How do you define "plenty"? What are your test numbers?
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Never below 3, normally about 5
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    We need a full set of results, including CYA, but 3-5ppm FC may not be sufficient depending on your CYA level to keep algae at bay, if you can do a full test (FC, CC, TA, CH, pH, CYA) those figures will greatly help in anyone assisting you.
    Stuart Murray
    Scotland UK
    UK NPPOC
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Got it - I will get those numbers together and re-post
    Mar 2007
    San Rafael, CA USA
    12,082
    Since you refer to corners and steps where the algae grows, that sounds like poor circulation. That allows the local chlorine level to get depleted. You might consider orienting your returns differently to try and get better circulation.
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Turns out it was low CYA - added some and things have stabilized.
    Thanks
    38,235
    That does not really make any sense.
    If there was no CYA and you maintained 3+ppm of FC, there is NO WAY algae would have grown.
    Granted that with a SWG you want the CYA to be a little higher to protect the FC from the sun. But, if the CYA was too low, you would have measured 0 FC because it would have been lost to the sun as fast as the SWG could generate it.
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    The chlorine was getting lost to the sun as it was being generated - there was very low chlorine - lower than I had reported. The pH was a tad high too, but the CYA level was the main culprit.
    38,235
    Quote Originally Posted by tomzo
    Ah, well there is the missing piece of information. Just wanted to be clear for any future browsers of the forum.
