Thread: Help with translating a 2-speed pump wiring diagram
    Jun 2012
    Louisville, KY
    50
    I'm trying to put in a new 1.5 HP, 230v 2 speed pump and just want to make sure I have the wiring right before I fry the thing. I'm wanting to wire it with a DPDT switch so I can have the "off" position in the middle.
    I found this diagram posted in another thread by forum member Ohm_Boy, which seems pretty straight forward:
    Where I get a little fuzzy is when I look at the diagram on the side is how to convert the "L2", "Low", and "High" in Ohm_Boy's diagram into the 1, 2, and 3or4 listed on my pump:
    ...and this diagram on the side of the pump shows a diagram with what I believe is a DPST, not the DPDT I want to put on:
    Now, am I correct in the below diagram in assuming that "L2" is my pump's 1, "Low" is my pump's 2, and "High" is my pump's 3or4? That would have it looking like this:
    Thanks in advance!
    38,000 gallon IG pool Plaster bottom & fiberglass walls
    Jandy FloPro 1.5hp, 2-speed pump
    Hayward S310T2 sand filter
    CompuPool CPSC36 SWG
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Re: Help with translating a 2-speed pump wiring diagram
    Your diagram is correct (I am an electrician/instrument tech). Just make sure your switch is rated to handle the motor current.
    Edit: in your drawing low and high speeds are reversed but it still works.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Jun 2012
    Louisville, KY
    50
    Quote Originally Posted by nedchavez
    Will do. I appreciate the quick response.
    38,248
    I agree the diagram on the pump is a little confusing using a spdt
    But, your last diagram is correct.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Louisville, KY
    50
    Does this one fit the bill?
    http://www.radioshack.com/product/index ... d=12708873
    NTE54-109 20A nylon paddle toggle switch.
    Slow make, slow break contacts
    Heavy duty AC rated, also suitable for low voltage DC applications
    Industry standard .500" diameter mounting hole
    Circuitry: DPDT
    Switch action: ON / OFF / ON
    Actuator: black polycarbonate
    Current rating: 20A 125-277VAC, 1 1/2 HP 125VAC, 2 HP 250VAC
    Insulation resistance: 100 megohms (min.)
    Dielectric strength: 1000V RMS (min.)
    Temperature rating: 32 to 185F
    Electrical life: 50,000 cycles
    Mechanical life: 100,000 cycles
    Mounting hole: .500"
    Jun 2007
    New Jersey
    653
    That will be fine, assuming it's out of the weather.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
