Thread: chlorine question
    Jun 2012
    Michigan
    92
    chlorine question
    I have a swg pool running on a 6 hr timer with my 2650 gallon pump running 8 hrs. The pump starts at about 9am the swg at about 9:15am. The sun is right on the pool daily.
    My kids were out of the pool for one month. Now that their back in the water &i went back to daily testing, i noticed my chlorine is staying at an orange level even with 6 kids in the pool daily & direct sunlight.
    I did the dpd fas test my FC was only 5 my CC was .5
    But the OTO is dark orange.
    PH is about 7.5
    What do you all suggest.
    Thanks
    18X48 Intex Metal Frame - about 6000 gallons, Intex 2,650-Gallon Sand Filter Pump, Intex Krystal Clear Saltwater Filtration System, BBB care method
    Nov 2010
    Calera, Al
    271
    Re: chlorine question
    What is your CYA? Could you post a full set of test results?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jun 2012
    Michigan
    92
    My CYA is about 75
    I haven't fine an ALK test recently
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Normally I would say trust your FAS-DPD test, but are you saying that the OTO chlorine test is showing orange? How much of the R-0870 powder are you using with the FAS-DPD test? Are you using a heaping spoonful? If you are, try it with two heaping spoonfuls, in case your FC is really high and you haven't been putting enough in.
    Here are the extended test kit instructions for the FAS-DPD test: http://www.troublefreepool.com/exten...1.html#p206393
    Jun 2012
    Michigan
    92
    Yes my oto I'd orange and I'll try with 2 heaping spoonfuls thanks
