Results 1 to 12 of 12
Thread: Hard Plumbing - Solar Heater or SWG last in the line?
    Jul 2012
    San Diego, CA
    96
    This is my first post here, but you all have helped my immensely over the last few months. I have a used 5,400 gallon splash-a-round, 9 x 19, soft sided pool. I recently replaced the pump with a hayward Power-Flo LX, as the bearings died on the old one. Now that I have everything taken apart I am considering getting rid of my flexible piping and hard plumbing with pvc.
    Previously I had everything in this order: pump,filter, Intex SWG, then finally my solar heater (a dome style solar pro heater). Is this correct? Or should my SWG be last in the line, allowing the chlorinated water to go directly into the pool, rather than through the solar heater than in?
    Thank you!
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    Mar 2012
    Amarillo, Texas
    341
    Re: Hard Plumbing - Solar Heater or SWG last in the line?
    I believe your solar heater should be last in line. I wouldn't want hot/hot water running through my other components.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Southern MA
    71
    If my solar heat kicks on after the sun is out for a while the 1st water coming out can be scalding - 130 degrees - if only briefly
    Maybe yours isn't that bad, but something to think about
    30 yr old 16x32' IG pool, ~16,600g, Hayward DE 4820 filter w/1.5hp pump, Solar heat
    Jul 2012
    San Diego, CA
    96
    Oh dear, it appears I have two different suggestions. The solar heater doesn't seem to heat our water up very much. But I don't know if that helps me one way or the other - not hot enough to burn people or equipment. Well shoot. I suppose I can just hook it up the way it was before with the heater being the last thing the water goes through. My only concern is that the Intex SWG manual says to make it the last thing in the line. However, the manual said nothing about what to do if a solar heater is in use.
    What I did was went online and found a cheap used small intex pump to run the solar heater completely separate from the main system, and the extra filtering is a plus.
    Intex Ultra Frame 14 x 42 3500 gals
    Intex SWG combo unit (2000 gph), screen door screening around cartridge:-).
    Jul 2010
    Philly
    332
    Quote Originally Posted by meganv
    SWG should be the last thing in line. Hydrogen gas is produced along with chlorine during the process. You don't want anything in between the SWG and the pool that could trap that gas. Hydrogen is flammable and can be explosive when trapped in containers like filters, heaters etc.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Jul 2012
    San Diego, CA
    96
    Alright, that makes sense (and is a frightening possibility to me). One other question - are bypass valves required when using a solar heater? The way the previous owner and myself used it, there is no bypass.
    Thanks again!
    Jul 2010
    Philly
    332
    Thanks again!
    A bypass is necessary when the pressure increase on your filter gauge rises above the panel manufacturers specs. My flat panels require a bypass if the pressure rises 10 lb. or more over what was my normal filter pressure before installing the panels. The two panels I have only increased pressure by 3 lbs but I have one installed because I can bypass the panels if there's a chance that they'll cool the water instead of heating it.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Jul 2012
    San Diego, CA
    96
    The pressure gauge on my pump always reads 15 psi. Is that too high? Could it be high because I do not have the bypass valve? I have no clue what kind of filter it is, there is no label on it. I bought this whole system used so I have been learning about it as I go.
    Also, this is the type of solar heater I have:
    http://www.walmart.com/ip/Aquaquik-U...eater/10807074
    Do you think this really heats the pool up at all? I have never run the pump without it, so I am not sure. Debating skipping it all together and just going with a solar blanket.
    Those things are a scam, unless you use like 20 them in a row. You should use a solar blanket either way. The thing with those heaters are that the compact size just does not have enough surface area to make a significant difference.
    Jul 2012
    Hamilton, Oh
    26
    not sure if this helps but after looking at solar heating i plan to divert the pool.water after the filter and before the swg and then return the hot water after the swg. that way the water going into the solar is filtered water only and the hot water coming out is not going into the swg. since i just completed our pool build so i and new to this but based on reading this make sense.
    any thoughts from other.
    Seablue Grecian IG 18' x 37'(3' to 8' depth), Pentair Superflo 1hp(SF-N1-1A), Pentair Sand Dollar SD80, CircuPool RJ60 SWCG,1 x Intellibrite 5G Color LED, Diving Board, Home Made Solar Tube Heating System
    Future Additions - IntellifloVS, Landscaping(DIY and Contracted-Under Construction)
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    That unit certainly won't generate scalding water, I have 160 square feet on my garage roof and if the water sits idle in those things too long on a hot day it can come out extremely hot, of course that's only until the idle water is cleared and then it runs at a much lower temp. The premise of solar panels is to move ALOT of water that is just a bit warmer instead of moving a little bit of hot water.
    Solar heating is about square footage, and you have hardly any. My recommendation, since you indicated it dosn't heat your pool, is loose that one since it's not worth the headache of putting inline and get a larger solar heater system (fafco, etc).
    This is my first year with solar panels and they do work.
    PS, you'll want an air valve in your system so the water drains when the pump is off and you don't have those scalding scenarios.
