Thread: Pump wiring
    Aug 2010
    Orlando, Florida
    41
    Pump wiring
    Just installed a new pump. Pentair SuperFlo 2 speed. The pump is running but only at one speed. From what I saw on the wiring diagram it said to connect the ground, red to 1 and black to 2. There is another wire capped off from the switch. Am I supposed to include that in the wiring or connect the black directly to it?
    17,000 gal, Posi-Flo Sta-Rite cartridge filter, IG, pebble, Water Ace (GE) 1 HP/1.25 SF 115/230V, 100 GPM (Resid.)/37.5 GPM (public pool), 102 SQ FT filter. Future upgrade: 250 SqFt filter.
    Jul 2009
    Olney, MD
    218
    Re: Pump wiring
    Is the switch to turn it on/off or hi/low? Might be helpful to post some pictures.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Aug 2010
    Orlando, Florida
    41
    Re: Pump wiring
    The switch is to select high or low speed. Here are some pictures. Thanks!
    22,548
    Re: Pump wiring
    Unhook the black wire from terminal #2 and hook it to the black wire that's capped off.
    Aug 2010
    Orlando, Florida
    41
    Re: Pump wiring
    Thanks Bama Rambler! Works like a charm now!
