Results 1 to 16 of 16
Thread: Am in need of a large dose of POP
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I just went through my 2nd new liner install in less than a month. The first new liner had a hole in the seam and they had to replace it after less than 2 weeks.
    They had me fill the pool halfway (took about 16 hours) and they came back sometime late in the afternoon the next day and cut the holes and stuff for the return and skimmer. It was evening before I could turn back on the water and finish filling (abut another 16 hours). That was last Thursday.
    I then added enough cya to get to 40-ish. Added chlorine to the pool and checked all the other levels. I have been fighting something in the water all week. The water never turned cloudy or green, but it would not hold chlorine at all. I have brushed and scrubbed several times this week. Just performed an OCLT again last night and still lost 3ppms. My cc's have ranged from 0-1 this whole time. The water is clear and sparkily. There is nothing in the skimmer or strainer baskets. My question is should I bump my chlorine levels up to mustard shock levels to see what happens or just ride it out?
    Could the water sitting in the pool for that day and a half with no chlorine or circulation be causing this? I am an avid reader of this site and use everything I have learned here, but this has got me puzzled. I will keep up the process, but should I be more aggressive about it? Thanks all!
    FC 17
    CC .5
    TC 17.5
    CYA 40-45
    Ph 7.5
    Ta 100
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Am in need of a large dose of POP
    Hey pepsi
    Yuck...I would advise to keep it at shock level and perhaps a bump to MA levels could not hurt for 1-2 days. Since it's been a week, have you tested your CYA level?
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Yes, it was around 40-45-ish. Sorry forgot to put that in there.
    30,426
    overnight-test-update-passed-oclt-t52231.html
    Stay the course! It may take a few days but you are killing organics. Go higher if you like and it may speed it up a bit but the overnight drop is actually good....you're killing something that persists in your pool.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Will do, nothing in the process and advice I get here has failed me yet!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Hang in there!
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Just an update.... I passed the OCLT after 8 nights. The water was always perfectly clear but would lose chlorine through the night, and I always had a cc of 0-1 through the process. So even though the water was clear the TF-test told me something was wrong. Everyone said stay the course and I did. So just a word of advice to everyone.....TRUST your results and the PROCESS, it works! Just because your water looks clear doen't mean there aren't some nasties trying to get ahold. Thanks everyone and keep up the good work!!
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by pepsiholic
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Was ist das "POP" ??
    38,371
    POP = Pool Owner Patience
    Jan 2012
    7,364
    Ahhh! Danke shoen!
    ohhh. I was thinking "pepsiholic ="pop."
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by imrodee
    Are you originally from Pennsylvania? Most people not from this area have never heard it called that....
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by YippeeSkippy
    Ahhh! Danke shoen!
    It confused me too the first time I read it a few weeks ago in another thread...
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by PAGirl
    That's what it is called around here too.
    Nice job on the cleanup pepsi
    No.. not me, I'm in TX. But I do know that some Northerner's call "soda's "pop."
    Helen
