Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: newbie struggle with mustard algae
    Jul 2012
    Riverside, CA
    51
    Before and During Pics
    First of all, thank TFP for helping a pool dummy like me to take back control of my pool. Richard320's pool school is much better than Leslie's! I am so glad I found this site two weeks ago.
    I wanted to show you guys some "after" pictures but it will take a long time to get there. So here are some "before" and "during" pictures.
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    Jul 2012
    Riverside, CA
    51
    "During" pictures are here
    Sorry. Did not know the limit of 3 files.
    Here is my pool now, looking better than ever Thanks to TFP!
    May 2012
    Boyd, Texas
    93
    Re: Before and During Pics
    Nice looking pool you have there. Making me jealous. :P
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    Jul 2012
    Riverside, CA
    51
    Remaining problems
    As you can see, the yellow scaling has faded significantly, but still there. I will try the low pH, low TA, plus frequent wire brushing treatment. More to learn.
    30,432
    Keep similar posts under the same thread so everyone can understand the continuity of your story.
    Jul 2012
    Riverside, CA
    51
    Right, sorry. I am newbie in many ways
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    pool looks great
    Jul 2012
    Riverside, CA
    51
    Updates...
    A month after I came to this site. Thank you for all your help! My pool has come a long way. But I still have problems. So here are more questions. Please give me some suggestions.
    I am mostly struggling with the yellow stain on the walls and floor. It keeps coming back after a couple of days, not as bad as shown in the "before" pictures, but could come quite close to that. It is not all over like before. It looks as if there is a level line, to the point where I drained the water down to during the "drain and fill" process. It's quite clean above the line, but with yellow stains below the line. When I brush, most of the newly developed yellow dusts come off easily. The stains would lighten but not disappear. With added chlorine and the pump on, it looks close to the "during" pictures. Then when I stop brushing for a day or so, there will be a new layer of yellow again.
    I try to maintain the FC level at 5-7. Daily drop is about 1.5. CC has never been over 0.5. I am also trying to lower pH and TA by adding muratic acid. But it is going on slowly. The pump is on for 6 hours a day.
    The numbers....
    FC 6.5
    CC <0.5
    pH 7.4
    TA 125
    CH 350
    CYA 40
    Water is clear
    Did you pass the overnight chlorine loss test?
    regardless your pool is not "clear" so you need to shock
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Does the yellow act like mustard algae? If so, you may wish to use mustard algae shock levels. If you didn't before, you might wish to check/clean the light niche and other hiding spots.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jul 2012
    Riverside, CA
    51
    I did go through the algae shock process after the refill. Please see this thread. I can do it again and I think I should. But the thing is, I can't seem to be able to make the stain disappear even at algae shock chlorine level and diligent wire brushing. I tried spot treat one area with pucks and fierce brushing that particular spot. Even so, it doesn't go off completely. I consulted Richard320 since he has seen my pool. He thought the scaling is imbedded with algae and cannot come off easily. So I am also trying to lower pH and TA with muratic acid. I also ordered a small wire brush, which might help with the lights and corners. Still, I am not sure how a new shock process would be different from last time. How do I know the process is over? I could pass the three standards and yet still have remaining stain. Or maybe the remaining stain means the "clear water" standard is not passed? Then I should keep shocking until all the stains disappear? I am afraid it will never end
    Quote Originally Posted by xiaobulu
    The remaining "dust" means that you havent passed clear water. As swamp woman suggested you might need mustard algae shock levels.
    Are you able to get a sample of the dust to look at under a microscope? Seeing if it is pollen vs algae would be really helpful.
    Jul 2012
    Riverside, CA
    51
    Quote Originally Posted by march2012
    I might be able to access a microscope. How to tell the difference? I doubt it would be pollen though. We do not seem to have yellow pollen around this area. It is probably algae.
    I did shock at mustard algae level last time (FC=24). The "dust" were gone before I ended the process. But some "stain" remains (please see my "remaining problem" pictures earlier in this thread). They were significantly lightened but are still there. They are very stubborn. They do not come off with regular brushing. In order to know whether I would ever be able to get rid of them, I hold a chlorine puck against one area, got into the water, and used a wire brush to scrub that particular area closely. But it would still not completely disappear, maybe because they are imbedded with the scaling, as suggested by Richard.
    I am not sure how to do it differently this time. If I need to hold FC at 24 until all the stains are gone, I don't know when or whether it would happen. That means a lot of scrubbing and chlorine, without seeing a light at the end of the tunnel. That's why I am dreading about it.
    Jul 2012
    Riverside, CA
    51
    My pool has a recurring mustard algae problem. I have done an 80% drain and fill to lower the cya. I shocked after the fill. My pool looked much better afterwards. But the algae keeps coming back. I know I need to be more thorough. So I am starting again. I really want to do it right this time. I won 't have much time once school starts.
    I am new to taking care of the pool? only learned which valve does what a month ago. I did read pool school but still not quite sure how to proceed, especially after the recent failed attempt. I will report the progress frequently to make sure I do not repeat my mistakes. Please help? Many thanks?
    8/24 dusk. fc is 5.5?cc?0.5?ph is 7.6. We added 2 gallons of 10% liquid chlorine and 1 gallon of 14.5% muratic acid . Brushed walls and floor (some yellow dusts came off. ) Turned the pump on. Tested again at 10:30pm ? fc is 17.
    30,432
    Re: newbie struggle with mustard algae
    We need to know your CYA level before we can suggest what to do next. Why did you add the acid?
    Jul 2012
    Riverside, CA
    51
    Thanks for your reply. The cya is 40. We added the acid because pool school says to keep ph at the lower side (7.2-7.4) while shocking and we have high ch, high TA, and scaling.
    Feb 2008
    Denton, TX
    5,061
    The key to your defeating the algae is persistence. Your shock level is an FC of 16. You could go even further and use chem geek's chlorine/CYA data for mustard algae and use a shock level FC of 24. The better you are at keeping your FC and shock level, the better you will do.
    Keep in mind that when you are shocking and your FC is 10 or more, your pH can read higher than it really is. We don't recommend lowering pH unless you can get a reliable reading and those tend to happen only when the FC is below 10 or so.
    30,432
    Please keep your "story" under one thread. I have merged your threads in order for you to get better responses.
    Attention all newbies. It is quite difficult to answer issues with insight when the story is spread over more than one thread. Few of us can remember all the issues we post about so when you split up your information, few of us will go to the trouble to try to piece it back together. Stay in the thread you start....even if there is a time lapse.
    Jul 2012
    Riverside, CA
    51
    Thank you. Is there a way for me to merge my own posts?
  20. Back To Top    #20
    Jul 2012
    Riverside, CA
    51
    Quote Originally Posted by 257WbyMag
    We tested pH before we shocked. The original FC level was 5.5.
    This morning (8/25) around 9am, FC=17 and CC<0.5. The water itself is clear, but the yellow stains on walls and floor remained. Does it mean we passed the overnight chlorine loss test and the CC criterion, but not the 3rd criterion?
    8/25 around 11am, FC=11 and CC<0.5. The water itself is clear. The yellow stains on walls and floor lightened but remain (look like the "during" pictures). We tried to brush some spots, but they did not come off, no more yellow dust coming loose. We added 2.6 gallons of 10% chlorine to reach mustard algae shock level (FC=24).
