Thread: BBB Method after 1 week and a question
    texasbrew's Avatar
    Aug 2007
    Humble, TX
    50
    My salt cell has died so I decided to switch over to BBB (last Saturday) until next year when I get a new one installed. My water reading (today before I added chems (bleach/acid) per Pool Calculator dosage) are as follows:
    20K gallons
    3100 PPM Salt
    3 FC
    3 AC
    7.8 PH
    90 TA
    380 CH
    40 CYA
    I added baking soda to bring the TA up from 65 to 90 last Saturday. Everything seems to be going ok. I am adding about 2 qts of bleach daily (new 8.25% kind). Every day I add 12 oz of acid per pool calc dosage to get to 7.6 and the following day I am back to 7.8. I am using the pool calc iphone app and I have double checked the settings. Is the daily acid addition going to continue or is that a result of the baking soda addition (will settle in in a bit more time)?
    Pool is in sun from about 9:00am to about 7:00pm right now and has a light swimmer load.
    Thanks.
    PG-500, WSM, 20K Gal gun pool w/ Aqua Pure 1400 SWG, flagstone coping, gray plaster, DE Filter, 400K BTU nat gas heater and Polaris 280 cleaner
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: BBB Method after 1 week and a question
    It should settle in. There was no need to raise TA to 90, which is likely pushing the PH up, especially if you have a water feature. The acid additions will drop TA back down to where your PH will stabilize.
    texasbrew's Avatar
    Aug 2007
    Humble, TX
    50
    ok...thanks
    I just looked at the advised settings but I will let the TA drift back down to where it was for the salt cell.
