Thread: chlorine test range with TF-100 kit
    May 2008
    NE Florida
    Can someone tell me what range of Cl the TF-100 kit will test to. Can it test to say 20, or do you have to dilute your water sample and multiply for numbers above 5. Thanks.
    22K gallon free form pebble tec pool, non screened, surrounded by 3, 100+ year old Live Oaks (pure misery for 3 months every spring) elevated non heated spa, jandy cl340 filter, Pentair Inteliflo 3hp pump, Jandy 1400 swg, infloor cleaning system which has had all outlets removed due to uselessness of system with the organic load the pool carries and now low rp
    There are two chlorine tests in the TF-100. The better one will test chlorine up to at least 50 to the nearest 0.5 (or 0.2 using alternate directions). The simpler "quick test" only goes up to 5.
