Thread: Is there a way to calculate CYA includes with dichlor?
    I've seen a lot of postings about concerns about too high CYA levels when using chlorine products. I seem to have the opposite problem.
    I have a SWG and often times my CYA always tends to drift downwards thru the course of the year (more so in summer). So I find I need to add more conditioner. But I find conditioner to be expensive. Also, I also like to shock my pool with dichlor, as it raises my chlorine level quickly, dissolves fast, and also bumps my CYA. So how can I calculate how high my CYA level will rise with dichlor? I don't really see any mention of how to calculate this anywhere.
    Marc
    20,000 in-ground pebble-coat pool with 60sf Jandy DE filter, Pentair Variable-Flow pump, Goldline Aquarite SWG, Dolphin Premiere robot, passive solar heating.
    38,315
    Re: Is there a way to calculate CYA includes with dichlor?
    look at the bottom of the poolcalculator. It will tell you effects of adding chemicals to your pool.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    How come you are losing CYA throughout the year?
    Excessive backwashing, splashout, leak? Ammonia producing algae?
    CYA doesn't evaporate with the water, it's just like salt, it stays behind.
    It's normal to lose some, or even all of it over the winter if you get bacteria or algae in there that eats it, and you loose a little from normal splashing and backwashing.
    But you shouldn't be losing a whole lot, just a little.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Mar 2007
    San Rafael, CA USA
    12,082
    As was mentioned, The Pool Calculator will tell you the effects for adding chemicals. For every 10 ppm Free Chlorine (FC) added by Dichlor, it also increases Cyanuric Acid (CYA) by 9 ppm.
