Thread: Thnking about pool cover
    tlwilson's Avatar
    Aug 2010
    Nebraska
    50
    I am considering purchasing a pool cover to reduce heat loss at night. My pool doesn't have a bottom drain, so the only circulation we get is through the skimmer and the returns. Will this be a problem for circulation if I have a cover on?
    24,000 Gal In Ground pool
    Vinyl Liner; Sand Filter
    Pentair Intelliflo pump
    Pentair IntelliChlor IC40 SWG
    Raypak Gas Heater
    Apr 2011
    Lynchburg VA
    393
    Re: Thnking about pool cover
    If the pool cover rests on the surface of the water, like a solar cover, it will affect the skimming ability of the skimmer. If the cover does not touch the wate it should not affect anything.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
