Thread: Vacation Tip
    Jun 2011
    Long Island, NY
    92
    Vacation Tip
    Have read several posts over the last year on maintaining pools using BBB while on extended vacation and just wanted to share my experience. Just recently returned from a 7 day vacation taking the family to FL to visit the Mouse. I typically keep my FC levels at or around 5 with a CYA of 60 in my SWG pool. We have a blue colored solar cover that goes on the pool every night and I put it on whenever we leave the pool unattended. The cover is certainly not clear but isn't solid either as light does get through it and it does a good job of keeping the pool warm. When I returned I tested and found that FC was up to 14. My pool gets sun from the minute the sun is up straight through till sundown and we didn't have anyone check on it while we were gone. (I did have someone to call in an emergency to pump the pool out as we had been getting some massive rain in NY)
    Turned the SWG down to 0% when I returned home to burn off some FC and get back down to my sweet spot around 5. I have to assume that the lack of use and the blue cover helped keep FC climbing without being burned off. I am meticulous about keeping my chemistry in line so pool was well balanced before I left. Just thought I would share this in hope it helps others using BBB take a worry free vacation knowing their pools will be fine when they get home!
    25K Gallon IG Vinyl Liner w/ concrete walls True "L" 16X32X16, Hayward EcoStar VS pump, Hayward Swimclear C4030 Filter, Hayward 21104T Heat Pro Titanium Heat Pump, Hayward Aqua Plus SWG + Automation, 2 Hayward Color Logic 4.0 LED lights, Polaris 9300 cleaner. TF-100 test kit.
    Jul 2009
    Olney, MD
    218
    Re: Vacation Tip
    I do not have a SWG, but I can vouch for the way a cover helps keep that chlorine loss to a minimum. I have taken my pool up to shock level and returned 7 days later with no problems at all!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Vacation Tip
    Good result then. Id be far happier knowing my FC was slowly rising throughout my vacation than worrying I was returning to a green abyss!
    Stuart Murray
    Scotland UK
    UK NPPOC
