Thread: Automatic water level controls
    The Villages, FL
    13
    I've seen some material on the Levelor systems that will add water to a pool automatically, is there any that will both add and remove water from the pool?
    Living in FL we get quite a bit of rain in the summer and in the 5 weeks I've had my new in ground pool I've had to lower the level 3 times due to the rain and add water twice due to splash out.
    And yes, I'm sure the level increase was due to the rain and not another source.
    Thanks
    Jul 2011
    Broken Arrow, OK (Tulsa)
    293
    Re: Automatic water level controls
    Ours is a new pool, installed with an autofill device to add water...but, like you, I'd be curious to know what's available to remove water after a heavy rain.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    The Villages, FL
    13
    Did some looking and all I have found so far is the Infinifill III from Wailani
    http://www.wailani.com/hrproducts/wls/wlsstand.shtml
    No idea on pricing.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I thought that most people who need this have simply installed an overflow drain pipe in their pool. Commonly I think this goes in the skimmer basket and it's just what it sounds like - a pipe (open) that leads to a drain off area that is above the normal level but below the top of the pool so that when water is getting too high it can flow off automatically. No need for electricity, no need for sensors, no automation, only passive flow.
    I'm sure there are situations where this solution is not appropriate - where the pool is not placed where passive overflow would work - but it does seem like a good solution for most people.
    Apr 2012
    Newton, NC
    173
    This is the Auto Fill unit that our PB supplied:
    http://www.inyopools.com/Products/14800404048454.htm
    They are running a pipe from the water faucet on the side of our house (used a T so we can still use the faucet normally) to the CMP Auto Fill. There is a drain hole in the Auto Fill. They have run a drain pipe to an area away from the pool. They will also be installing a drain pipe from the skimmer. So, I am hopeful that these 2 drains will be sufficient to handle heavy rains. The placement and alignment of the Auto Fill/Drain is critical.
    The PB mentioned that when the concrete guys pour the decking they often step on or kick the Auto Fill and knock it out of alignment. They got our Auto Fill positioned and then put concrete around it so that it doesn't move.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
