Results 1 to 11 of 11
Thread: How do you keep the cover on & run pump on AG Intex 10'x30"?
    We have a cover on our 10'x30" Intex Easy Set, it's been so dry here in the mid west that the leaves are falling off the trees already!! When we run the pump with the cover on, the water is pushed through the small holes in the cover, and water gets on top of the cover.
    Is there something, some way to have the cover on....and still run the pump without the water getting on top of the cover??
    I was thinking of putting a pool floatie under the cover....??!!
    Thanks in advance for any ideas!! We have to skim leaves out 4-6 times a day....if not more!! (crazy!)
    Donna
    KCMO
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: How do you keep the cover on & run pump on AG Intex 10'x
    Welcome to tfp, dlmurphy13
    I think your idea is a good one.
    Not exactly sure how the water is getting on your cover, but if you pool return is pointing up, then maybe put a 2X4 or something to prop up the pipe on the outside to direct the return flow deeper in the pool.
    Aug 2011
    Gainesville, fl
    53
    I did just that. I bought a float called the island from walmart. I believe it is 8 ft across. It gives me enough room to have pretty good water flow around the float. It has also made putting the cover on and off a little easier.
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If you have any of those noodle laying around, they might work.
    I use 3 beach balls from Dollar Tree, but I like the 8' float idea better.
    2013: UltraFrame 16'x48", 1600gph Sand Filter
    2012: Easy Set 10'x30"
    Thanks for all the ideas! Using the 2x4 under the return pipe to go deeper into the pool worked!! I no longer need to put in floaties....but I kinda like the beachball idea to help possibly keep leaves from gathering too much on the cover surface!
    Thanks again for the ideas!!!
    Apr 2012
    Latrobe, Pa
    11
    If your still looking for a nicer lookig solution heres what i did. You will need a blue adapter which come with the ultra frame pools for the skimmer. short piece of inch and a half pvc, a 90 degree elbow, and a 1 1/2 to 3/4 bushing. You will need to sand the blue fittings lip down until the small section of pipe fits snug preferly have to use a rubber mallet to ensure tight so it will not blow off. Once attached you simply screw onto return line and firmly push the 90 degree elbow on with the bushing in the opposite end. The purpose of the bushing is to create water pressure and if you have any kind of heater (solar or otherwise) it will push the heated water to the bottom of the pool.
    Intex 14' x 42". 3557 Gallons, 1600 GPH Intex Sand Filter, Intex CS8110 Swg Post 2009, 2x20 SunHeater Panel.
    Custom Built Equipment Deck, Small Fountain, Intex LED Light, Custom Built Manifold.
    whatsup201178, can you post a picture of that so I can have a visual of what you are talking about?? Thanks so much!!!
    Apr 2012
    Latrobe, Pa
    11
    This is what it looks liike completed. sorry i cannot provide pictures of it installed. Pools was torn down for winter yesterday
    Awesome! Thanks!!!
    The blue part screws onto where the return is, inside the pool...pointing down!!
    Great idea!!!
    Apr 2012
    Latrobe, Pa
    11
    When I had the cover off I would turn it towards the wall facing away from the suction and it gave me a pretty good water current with my pump size. The thermometer was usually at a 45 degree angle. Just be sure to remove it before swimming I bet it would not feel to good on a bare back.
