Thread: Partial Water Change
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I had high CYA so I just did about 50% water change.
    I am going to check everything and see if the CYA is where it needs to be. If not, I'll drop some more water out.
    Once I get the CYA where it needs to be, what order should I balance the other chemicals in.
    I'm a BBB pool.
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    38,262
    Re: Partial Water Change
    Post up a full set of results and we can help form a plan.
    What does the water look like? Any reason to have to go through the shock process?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Water looks like Gin!
    I know I'll most likely have to adjust Alkalinity, Calcium, and pH. Fixing Borates will be last.
    Was wondering what order to adjust them in.
    Chlorine of my add water is 2 ppm, city water.
    38,262
    FC and pH are the most important.
    CH might need adjusted (only can adjust up)
    TA usually can be ignored unless it is too low. There is a process in Pool School to lower it if you want.
    Certainly want pH and TA correct before you add more borates though.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    OK, did a check today.
    I thought I changed about 40 -50%. Not sure though, and I chickened out when one end of the pool got low
    Here's the numbers
    CYA: 100
    CL 2
    pH 7.2
    TA 50
    CH 240
    I'm pulling another big slug back out of it right now. I really want the CYA down, I use Tablets and it'll go up for sure.
    I have the Taylor kit and the CYA test seems kinda screwy, is there a better one out there?
    The guys at the Pool store use a bigger one, but it must take a bunch more reagent I would think.
