Results 1 to 7 of 7
Thread: Pool Formula's
    Pool Formula's
    Does anyone have the formulas to do a manual calculation based on "The Pool Calculator"?
    This will be useful if my computer is in for repair.
    35,000 gal IG w/ spa completed Oct 2012, grey quartz plaster, SWG (nature2 - no minerals), Jandy cartridge filter, Heater, Polaris 280 w/ booster
    Apr 2011
    Lynchburg VA
    393
    Re: Pool Formula's
    There is a smart phone app!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Pool Formula's
    Quote Originally Posted by BadOleRoss
    Which one?
    I have one - and I like it OK but it isn't as flexible as the website. I really wish the web owners would create a nicer mobile friendly website for use by those of us with smartphones or update the app to be more like the site.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool Formula's
    The Pool Calculator formulas were mostly based on the formulas and results from the PoolEquations spreadsheet, though the more complex calculations were simplified and put into lookup tables (mostly for the pH-related calculations). If you are an advanced user, you can see the Constants section to find molecular weights and densities which are the primary factors used in the conversion calculations. It's the calculations involving pH (i.e. changing pH requires how much chemical and how much does pH change from adding a certain amount of chemical) that are complex and best described using a table that has various TA and whether borates are used (or the level of borates).
    Your best bet is just to put in a fixed amount for the chemicals you use the most and then just scale accordingly. So put in your specific pool size into The Pool Calculator and put in a difference in TA between Now and Target of 10 ppm to see how much baking soda it takes to increase or Muriatic Acid to decrease. Same with FC, CH, CYA, Borates. The relationship is a fixed proportion for a given pool size.
    38,305
    Re: Pool Formula's
    Depends on your phone.
    Simple Pool on android (developer is a member)
    Pool Calculator on iphone
    Saw some mention of Pool Pal as well, but not sure who maintains it
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Pool Formula's
    I have simple pool - and I like it mostly but it's a little frustrating compared with poolcalculator.com. The iphone app pool-calculator has bad reviews for things like not keeping goals saved, no communication from developer, etc.
    There are several others but not clear what they do.
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Pool Formula's
    I'm going to review a couple of the iPhone apps as I get time.
