Thread: Using test kit to test chlorine in tap water
    Jun 2008
    Marana, AZ
    347
    Hubby came into bedroom this morning and asked if there was any reason he should be smelling chlorine in the kitchen. All pool chlorine was outside, and I checked the bleach bottle in the bathroom - no leaks and the lid was tight. He then told me he realized the smell was coming from the tap water, as he was filling the sink at the time. I tested it - 2.5ppm of total chlorine! (didn't test to see if it was all FC, or if some was CC.) They must have just treated it. Oh the joys of living 1/4 mile from the water treatment facility.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Using test kit to test chlorine in tap water
    It will generally test as CC.
    Mar 2007
    San Rafael, CA USA
    12,082
    If it's chlorine, it will show up as FC; if it's monochloramine it will show up as CC.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    In my neck of the woods we are told to expect between 1-3ppm (chlorine) I find this is true. We are a LONG LONG LONG way from the treatment plant.
    I think one reason it smells strongly is that it is under huge pressure until it leaves the pipes and some of the FC may outgas when the pressure is released. I know that my hose water can be very cloudy at times - from bubbles! If you leave it for a few minutes all the cloudiness turns to bubbles and you can watch them rise and disappear.
