Thread: Pool Design & Layout Process - Input Requested
    Jul 2012
    Cary, NC (Raleigh)
    69
    Going down the road of investigating installing a vinyl lined IG pool but that feeling of being overwhelmed by the whole process is starting to creep in
    We have interviewed 2 pool builders thus far and we have a good idea of what we want in our yard but I'm a bit lost on how others have gone about their whole design/layout process. The pool builders install pools and have "contacts" for the other trades but its up to me to coordinate and quote them out. In order to do a good job and not be lead around by contractors I feel the need to have the whole pool design layed out and detailed down to the square foot but thats easier said than done and harder to convey.
    Did you start with a landscape architect and do a full yard layout including pool, decking, patios, retaining walls, drainage, etc...?
    Did you interview pool builders first and select one before designing the pool deck and receiving quotes for the other items?
    How did you get accurate quotes for concrete decking, patios, electrical and did you use a detailed blueprint of your layout or how did you do that?
    I'd like to better understand how others went about the whole pool building, design, quoting process and what steps were followed and in what order. Would help make me feel better!
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    Re: Pool Design & Layout Process - Input Requested
    For us, our PB did most of the work. We had to arrange on our own:
    -- Fencing
    -- (Wood) deck reconfiguration
    -- Sprinkler system reconfiguration
    -- Electrical
    Our pool design was done in a program that provided 3D renderings of what the final thing would look like, so it made that part of it much easier to understand. We knew where we wanted the equipment pad, and all of our quotes used that location.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
