Thread: Sun Deck???
    Sun Deck???
    Hi all,
    When we installed the pool, we had sundeck installed. We had to have some repairs done and now have some new concrete... how hard is it to replicate the sun deck? is it something a do it yourselfer can do??? anyone have any tips?
    Baloo
    16,900 gal in-ground salt water pool/spa
    Hayward Goldline Chlorine Generator (t-15)
    Whisperflo 2 speed pump
    4 cartridge filter system... not sure what number
    400k btu natural gas heater
    37,416
    Re: Sun Deck???
    I assume you mean the textured "Kool" decking that is sprayed on concrete.
    Not to burst your bubble, but when we had our deck done ... due to shear laziness as far as I can tell ... they only textured half of the deck one day and came back the next day to do the other half. The textures were COMPLETELY different. Not sure if it was different equipment or a different operator or a different mixture or what. They ended up having to re-coat all of it until I decided the textures were "close enough".
    So, apparently matching the texture is difficult for those the should know what they are doing, and also the color fades over time, so that could be a problem as well.
    Re: Sun Deck???
    from what i can tell, the sun deck is a lot thinner than kool deck. sundeck is non-pourous so that cracks are less of an issue. We also plan to recolor the entire deck so faiding shouldnt be an issue. Not sure of the undercoats.. but it looks like you take a loose morter-type mix and sprinkle it on the concrete, then smooth out with a flat trowel. I know it is probably much more complicated, but the pool contractors have dried up with the economy, and I cannot find anyone to do a small job.
    Baloo
    Baloo
    Aug 2010
    New Caney, TX 77357
    184
    Re: Sun Deck???
    I was not home for the first phase of our Sundek install, only the color treatment. We had it applied to the new pool decking and to the existing covered patio (approx. 8 years old at the time) that the decking mates up to. Can't tell the difference between them, looks great.
    From one contractor's Sundek FAQ page:
    How is Sundek applied?
    Part of it is sprayed on with an Acoustic Sprayer and part of it is troweled.
    What does it look like?
    It is a textured surface. The base coat, if necessary on old concrete, is installed as a smooth coat. After that is dry, a texture coat is sprayed out of an Acoustic Sprayer with material covering 70-80% of the base coat in small drops. These drops are then troweled smooth and are comfortable to walk on. A colored finish is then applied.
    LINK: http://www.cardinalaquatechpools.com/p5sdfaq.htm#why
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
