Results 1 to 12 of 12
Thread: intex 12x24 nightmare!
    I am new here and my husband and i are new to above ground pools. We got the 12x24 itex pool and so far this pool has caused us nothing but pure torture. I knew the ground needed to be level but i dont think i realized just how unlevel our yard was! We worked for a month trying to level our yard ourselves with shovels. Anyway fast forward to 2 days ago. We thought we were level, and we may still be leve,l the problem is one side of our supports sunk bad and its only on one side in the very corner. I dont know how that happened because we used treated wood and our ground was so friggin hard everywhere (except there obviously) Anyway the water went to that side and at first it was off by about 3 inches, by the next morning it was off by 4. So we drained the pool and now its just sitting in the heat outside. We are getting some dirt from a friend and going to try to build up that corner where the support sunk. Will that work? What would you do? Also is it okay to have the pool sit out in the sun with no water for hours? I acn not tell you how many tears have been spilt over this project. I can not have it sink in that spot again! How do we stop it from sinking in there?
    12x24 Intex AGP
    38,299
    Re: intex 12x24 nightmare!
    Welcome
    Sorry to hear about your troubles and not sure I will be much help personally, but have a few questions.
    What did you do to level the yard? The proper way is to determine the lowest point and then remove dirt until everything is that low so that you are sitting on "hard" undisturbed dirt. I am wondering if you tried to fill in the low area and that is where the pool is sinking. Generally your need to be very careful to fully compact the ground if you are trying to build up.
    Hopefully others can offer thoughts on how to add support.
    No we did it just like you described, thankfully we figured that out because my husbands father told us what to do as he had an above ground pool for years. The only thing i can think of is that the ground did seem a little easier to dig through in that area and maybe that's why it is sinking in that area? I am ready to throw in the towel but my husband is adamant we just try again. I just feel like how on earth are we going to stop it from sinking?
    12x24 Intex AGP
    38,299
    Possibly rent a compactor for that area to make sure it can not settle more. Then use something with a large footprint under the legs in that area. Best I can come up with. How larger were the pieces of wood you used under the legs?
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    You may have hit an area that was previously filled and now it may have given in, there are some threads here about jacking up Intex legs.
    Jun 2012
    MA
    347
    What size wood do you have under the legs.
    It was 1.5 inches thick and so far the pool is good everywhere else, i am afraid that was too thin? Last night we got some very thick concrete pieces and put it under 2 of the supports and it is filling again, so far it is almost half full and looks okay (fingers crossed). If this dosent work i am selling this thing and getting something much smaller!
    12x24 Intex AGP
    38,299
    It is not the thickness of the wood that matters ... what is the footprint (looking down on the ground). That spreads the weight over more of the ground so less likely to sink.
    Apr 2012
    SW Ohio
    456
    i would have used 2x12x8 treated wood and layed them end to end that way no legs would be on a butt joint and then screwed a treated 2x4 down the outside edge to act as a stop so if the legs shifted outward it could not have came off the 2x12's...........jmo....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    fast1971chevelle- I never said anything about it coming off the wood. In the directions it says to use 1 and a quater thick i believe. So thats why we did not use 2 inches.
    Anyway i we are almost full now and it looks good thank god!
    12x24 Intex AGP
    Just an update: The pool is filled and looks awesome! It is about an inch off on one corner but from what i read here that okay. I love my new pool!
    Thanks for all your advice!
    12x24 Intex AGP
    May 2012
    Boyd, Texas
    93
    Congrats. Try not to worry about it to much. I've been amazed by how bad some intex pools are installed and the fact that they remain upright.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
