Results 1 to 15 of 15
Thread: Newbie excited to learn
    Hello to all! I have been reading the forum for a few days now after searching if I could use bleach as chlorine. I have decided to drink the Kool-Aid so to speak and dive right in. I do not have a testing kit yet so i just went and had the water tested at my local pool store. Let me know what you guys think I should do!
    FC .07
    TC .07
    CC 0
    pH 7.8
    Hardness 872
    TA 79
    CYA 47
    Copper 0
    Iron 0
    Total Dissolved Solids 1800
    They recommended adding 6.5 lbs of alkalinity up and 9 Trichlor tabs in the floater. I popped this info in the pool calculator and and added 192oz of bleach as i could see some small patches of green on the walls. The water is clear.
    Ready, Set, GO!!!
    20,000 gallon, IG, plaster, cartridge filter @ 150 gpm, Jandy 2 HP ePump, waterfall, overflowing spa, fan jet water feature, Del Ozone Eclipse 1 ozonator (not working)
    Cedar Park, TX (Austin)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Newbie excited to learn
    Welcome to tfp, Texastrav75
    First, you need to get your own appropriate test kit, since pool store results tend to be unreliable and not often enough for effective pool maintenance. I suggest the tf-100, most bang for buck and fast shipping.
    Quote Originally Posted by Texastrav75
    Assuming that is algae, you need to do the shockng process, it is a process of holding your chlorine levels high until you pass the three criteria mentioned in the pool school article.
    Also, mixing pool store recomendations with ours will not work. Both of the recommendations you got:
    ...would not be our recommendations. Both are not what your pool needs, according to their tests.
    Lastly, once you get rid of the algae, here is a pool school article that has our recommended levels: http://www.troublefreepool.com/pool-...mmended_levels
    Let us know if you have questions.
    Until I get the TF 100, should I use bleach to keep my chlorine levels up? I have been using buckets and buckets of granular shock and pile of pucks this past year and never seem to be able to keep chlorine in the pool. I'm sure my CH is gonna be crazy from all the cal hypo I've pumped in the water. Or should I just wait until I get the kit and start??? Thanks for all the help. I am pumped to learn this process!!!
    38,524
    Welcome to TFP!!!
    Definitely stick to liquid chlorine and try to keep the FC around 5ppm if you can test that high. ASSUMING we trust those test results, your CYA in a good place and your CH (hardness) is WAY up there ... so no more solid chlorine.
    When you get your kit, test your tap water for CH as well. The high CH is manageable by keeping close control of your pH, but replacing some of the water to lower it may not be a bad idea.
    Thanks! Have the TF100 ordered! Also have another quick question. I have an ozonator that has gone to heaven. Recommend replacing it? If not, shoul I remove it or just leave it hooked up?
    38,524
    Not worth the money to replace the ozone in an outdoor pool. Just keep adequate FC levels based on your CYA.
    You can probably leave it, but if it is easy to remove, I might go that route.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome
    Aug 2011
    Central Valley California
    121
    Welcome. You'll love the way the liquid chlorine only method works.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    Hooray! I got my TF-100. Only problem was the CYA tube was cracked so it leaked and I couldn't get a CYA reading. Here are my results.....teach me oh wise ones!!
    FC-0
    CC-1.0
    pH-7.5
    TA-120
    CH-880 (eff you pool store telling me to keep shocking)
    CYA-???
    Just so I know for sure, now I enter these in the pool calculator, right
    38,524
    PM duraleigh (member72.html) if you have not already contacted them about the cracked tube.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    In the meantime if the crack is only causing it to leak you could try clear packing tape over the crack as a way to get a reading until the tube is replaced.
    30,432
    I think some carefully placed duct tape or some grade school modeling clay may hold it well enough for you to get a test. Your replacement tube is packed and out for delivery to the Post Office this AM....sorry.
    Butterfly's Avatar
    South Carolina
    10,045
    Dave (duraleigh), you have got to do something about those elves! They might have been using that tube for tequila shots
    Have you thought about unlocking the barn and giving them a day off?
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    FC-0
    CC-1.0
    pH-7.5
    TA-120
    CYA-???
    Welcome to the forum I suggest you lower the pH to 7.2ish and keep it there until until the CH comes down.
    We recommend about 30 minutes of pump/filter time between adding chems. So if you add muriatic acid to lower the pH, wait half an hour or so before you add bleach/liquid chlorine.
    Hopefully you'll post the CYA test result soon
    btw, you will love the BBB method.
    Jun 2012
    Mint Hill, NC
    2,589
    The reason I suggested packing tape is that it is clear and I figured that anything opaque might skew the results - is that a non-issue?
