Results 1 to 9 of 9
Thread: Help..V Speed or 1 Speed Pump.. Am I getting Ripped off???
    Hi Pool forum,
    I have a 40K gallon salt in ground pool with spa and my Jandy Aqualink 10 year old single speed pool pump went out. I went online to amazon.com and bought the Pentair IntelliFlo FS+SVRS High Performance pump thinking that I would qualify for a rebate from my electric company and save significant dollars on my energy bill each month.
    However, I had a pool guy come over to take a look at installing and he said that it what I bought was a piece of junk, that Inteliflow VS's wont last more then 4 years and the cost to replace the motor is almost as much as the pump itself. Plus I would need to buy some $200 controller and pay him $250 to install. He said, I should return it and have him put in a single speed whisperflow which would include installation for $950.
    Does anybody in the forum here think this is accurate?
    The cost of the intelliflow was $1,100 and I am going to have to pay for shipping and restocking fees which will amount to a $200 loss. I wont qualify for the electric discount and I likely wont save any money on my electric bill. I just dont want to return it until I get some feedback from you guys here on the forum. I am in southern california and my electric rates are extraordinarly high.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Help..V Speed or 1 Speed Pump.. Am I getting Ripped off?
    Hello! You would need an extra controller to make the Pentair IntelliFlo work with your Jandy Aqualink system. You could also just use the built in controller on the IntelliFlo but then it won't work through your Aqualink system. If you want a VS pump that interfaces with your Aqualink system directly you can go with a Jandy ePump or FloPro VS. The IntelliFlo is in my opinion the best VS pump around. If you want to save energy I would at least go with a dual speed not a single speed. The automation part of his assessment is right but I don't know why he thinks the IntelliFlo is junk. It's my personal favorite pump above anything else on the market.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Your PG is right about one thing, the VS motors are expensive and so are the drives but there have been only a few failures reported on the forums so the comment about junk maybe a little over the top. Ask him for proof.
    As for the best VS pump, I guess that depends on your criteria. The most efficient, based on measurements, seems to be the EcoStar. The most field time is certainly the Intelliflo.
    Another option to consider is a two speed pump. You get nearly all of the energy savings at a much lower price point.
    Mark
    38,546
    Quote Originally Posted by mas985
    And it should integrate right into your current automation if you have the relays available.
    Christian's Avatar
    Jul 2012
    304
    As someone who sells a lot of pool pumps I can say I would not personally buy the EcoStar. It may be a hair more efficient but the feedback I've gotten on them from customers has been less than ideal.
    Thank you guys...this has all been very helpful. What is a reasonable cost I should be charged to have the Intelliflow installed into my Aqualink system?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Quote Originally Posted by Christian
    The EcoStar is about 18% more efficient on full speed and close to 35% more efficient at the lower speeds for the same flow rate so I would say it is quite a bit more efficient than the Intelliflo. But I would agree that there have been a few reports of failures, mainly bad seals, but there have also been several reports of drive failures on the Intelliflo which costs a lot more to replace than a seal.
    Mark
    Christian's Avatar
    Jul 2012
    304
    I believe those energy efficiency numbers are based on the original VS-3050 not the current version. I'm not sure what the difference is with the current version as far as efficiency but I believe it's a lot closer. I've sold hundreds of pumps and while the EcoStar is a slightly more efficient pump it seems to have a far higher instance of failure. I checked around but couldn't find the numbers as far as efficiency of the current IntelliFlo 011018 against the EcoStar. If anyone has a link with that information I'd love to check it out!
    mas985's Avatar
    Pleasanton, CA
    11,743
    The CEC database has all versions and they are all the same. You can look the data up here:
    http://www.appliances.energy.ca.gov/AdvancedSearch.aspx
    But here is the data in table form:
    [table=2:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Manufacturer Name[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Brand Name[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Model Number[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Speed RPM[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pool Pump Motor Capacity[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Motor Service Factor[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Motor Efficiency %[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Nameplate HP[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-A gpm Flow[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-A Power Watts[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-A Energy Factor[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-B gpm Flow[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-B Power Watts[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-B Energy Factor[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-C gpm Flow[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-C Power Watts[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Curve-C Energy Factor[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Hayward Pool Products[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]EcoStar[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]HCP3400VSP[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1000[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]33[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]20[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]88[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.64[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]12[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]80[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]28[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]17.5[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Hayward Pool Products[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]EcoStar[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]HCP3400VSP*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]84.3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2005[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.12[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]42[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1651[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.53[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]98[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2324[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.53[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo Variable Speed[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo Variable Speed*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VF[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VF*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS+SVRS[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1100[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]145[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.93[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]15[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]132[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]33[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]150[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.2[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS+SVRS*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS-3050[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]Pentair Water Pool and Spa[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS-3050*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][/table:c2tepm9b]
    Mark
